Author Topic: AutoCAD 2015 .NET Wizard  (Read 18318 times)
BlackBox
« on: July 22, 2014, 05:10:22 PM »
Is it just me, or does anyone else have an issue with the new wizard, where the 2015 C# project template is only visible when .NET Framework 4.0 is specified in the New Project dialog, whereas the 2015 VB project template is visible when .NET Framework 4.5 is specified?
Using Visual Studio 2013 Ultimate (thank you Microsoft BizSpark!).
Re: AutoCAD 2015 .NET Wizard
« Reply #1 on: July 22, 2014, 05:37:09 PM »
First question:
Where did you get the ac2015 .NET wizard for VS2013?
I've been using a modified 2014 wizard ( when I use a wizard).
Using 2013 Pro, not Ultimate.
I don't usually use VB.net at all,
but interestingly;
2014 vb recognises net 4 no others.
2014 c# recognises 4.5, no others.
BlackBox
« Reply #2 on: July 23, 2014, 08:32:10 AM »
First question:
Thanks for the prompt response, Kerry.
I just recently (in the last week or two?), downloaded the 2015 .NET Wizard from here (bottom of page), after reading Kean's post here:
Quote from: Kean
<snip>
Do bear in mind that to target .NET 4.5 – which is a requirement to use the API enhancements in AutoCAD 2015 – you will need to use Visual Studio 2012 or 2013: VS2010 cannot target .NET 4.5. (ObjectARX developers will have to use the toolset from VS2012 to compile their C++ modules, as that’s the compiler being used to build AutoCAD.) I’m personally now using VS2013 as a primary IDE, but make use of the VS2012 toolset when building ObjectARX modules.
<snip>
Now, I have not installed VS2012 as I had done previously, before upgrading our workstations from Win7 to Win8.1 - not sure that would change this behavior though, just not sure if I'm missing something essential for my low hanging fruit Exchange apps, as they debug and compile just fine for 2012-2015.
I've historically used Express versions only, and would still if I weren't accepted into BizSpark; I can go get VS2012 if it is somehow needed.
but interestingly;
Nor do I, since I've been swayed to the [C#]-side of the force.
« Last Edit: July 23, 2014, 09:02:36 AM by BlackBox »
« Reply #3 on: July 23, 2014, 08:41:48 AM »
Weird for me. I don't see ac2015 for VS2013 in that listing.
BlackBox
« Reply #4 on: July 23, 2014, 08:51:13 AM »
Interestingly, I have just uninstalled the 2015 wizard, and an extracted copy of the .ZIP I had made that remained, suddenly shows up under .NET 4.5 Framework in VS2013.
Also, FWIW, I re-installed both 2014 & 2015 wizards and the former only installs to ..\Documents\Visual Studio 2012\ folder, whereas the latter installs there, as well as ..\Documents\Visual Studio 2013\ folder... However, neither the extracted, nor the new .ZIP are shown under .NET 4.5 Framework again. Grr.
BlackBox
« Reply #5 on: July 23, 2014, 08:55:46 AM »
Quote from: Kean
<snip>
<snip>
Weird that Kean would use something that's not listed on that web page... Good thing all of my solutions open, debug, and compile just fine with it... Just the template 'placement' is a bit wonky. :-)
[Edit] - Also weird that the 2015 wizard 'knows' to install for an IDE that it doesn't support (according to that web page)... So weird:
... the [2015 wizard] installs [to the ..\Documents\Visual Studio 2012\ folder], as well as ..\Documents\Visual Studio 2013\ folder.
« Last Edit: July 23, 2014, 09:09:43 AM by BlackBox »
« Reply #6 on: July 23, 2014, 09:47:45 AM »
Looks like I'm having a really bad day,
I can't see a link on that page of Through The Interface for the .NET wizard for ac2015 in VS2013.
Jeff H
« Reply #7 on: July 23, 2014, 09:54:11 AM »
I do not see it at the bottom of Through the Interface but do see it on the ADN link
http://images.autodesk.com/adsk/files/AutoCAD_2015_dotnet_wizards.zip
« Reply #8 on: July 23, 2014, 09:55:13 AM »
Without changing the subject too much ;
this is from the 2010 API wishlist http://through-the-interface.typepad.com/through_the_interface/2010/05/theres-still-time-to-fill-out-the-2010-api-wishlist-surveys.html
How many of those items have been addressed in the last 4 years ??
AutoDEsk should start taking lessons from someone like Unity about supporting developers and documentation and tutorials ....
« Reply #9 on: July 23, 2014, 09:59:48 AM »
Jeff, Have you tried that ?? It's dated 2013/11/19. Does it support ac2015 in VS2013 ??
This is a month later.
https://github.com/ADN-DevTech/AutoCAD-Net-Wizards/blob/master/AutoCADNetWizardsInstaller/AutoCADNetWizards.msi
« Last Edit: July 23, 2014, 10:03:25 AM by Kerry »
BlackBox
« Reply #10 on: July 23, 2014, 10:01:27 AM »
I'm sorry to hear that, Kerry; you do seem to be particularly prickly today.
I do not recall saying that I found a link for 'the .NET wizard for ac2015 in VS2013', well, at all.
I did however site Kean as stating that one would 'need Visual Studio 2012 or 2013' and that the latter is what he (Kean) uses as primary IDE. Further, the fact is that the 2015 wizard installs to 2013's ..\ProjectTemplates\ folder, regardless of the non-existent "2013" string on the ADN web page, or link elsewhere.
The purpose of this thread was to confirm that there's an issue with the 2015 wizard's C# template that is installed for 2013 IDE; nothing more.
I appreciate your time nonetheless, and sincerely hope that your day gets better.
Cheers
« Last Edit: July 23, 2014, 10:04:42 AM by BlackBox »
BlackBox
« Reply #11 on: July 23, 2014, 10:04:02 AM »
Yes, mostly... See this for more information on some shortcomings.
LE3
« Reply #12 on: July 23, 2014, 10:06:20 AM »
If they can't take care of spelling, on their own docs.....(for example: arxmgd.chm) - see image :)
« Reply #13 on: July 23, 2014, 10:06:40 AM »
I do not recall saying that I found a link for the .NET wizard for ac2015 in VS2013, well, at all.
Cheers
BlackBox,
Your original post says you are using 2013 Ultimate to develop for ac2015, and that the wizard (with references to Keans blog) was faulty.
I don't see how I can read that any other way.
BlackBox
« Reply #14 on: July 23, 2014, 10:35:07 AM »
Your original post says you are using 2013 Ultimate to develop for ac2015...
I am.
... and that the wizard (with references to Keans blog) was faulty.
It is.
Nor do I, and yet you persist, despite yourself using 'a modified 2014 wizard in VS2013 Pro' (is there a link for that?)... So weird.
