Author Topic: Batch insert reference(Xref)  (Read 4404 times)
Matt__W
  • I like my water diluted.
Re: Batch insert reference(Xref)
« Reply #15 on: July 23, 2014, 10:23:12 AM »
Re:M@yhem
xref command can't select multiple DWGs.
It has been able to do so for a few years now.  What version are you using??
ACad 2010
You can use the CLASSICXREF command in select multiple XREFs.  No need for a custom app.
Autodesk Expert Elite
andy_lee
« Reply #16 on: July 23, 2014, 11:10:06 AM »
Re:M@yhem
ACad 2010
Yes, is Autocad2010
andy.
Best regards.
cmwade77
« Reply #17 on: July 28, 2014, 05:01:03 PM »
Yes, you can use classicxref; however, all xrefs will be inserted at the same insertion point.
andy_lee
« Reply #18 on: July 28, 2014, 09:11:30 PM »
Thanks to all.
I already have a good routine to do it.
andy.
Best regards.
