Author Topic: How to make a reactor to enable rxxx commands.  (Read 3281 times)
haibinpro
« on: July 21, 2014, 02:33:12 AM »
when type r12,it will make a c:r12 command like this
(defun c:r12()
(command "fillet" "r" 12 "")
(command "fillet")
when type r102,it will make a c:r102 command like this
(defun c:r102()
(command "fillet" "r" 102 "")
(command "fillet")
I collect some code may help to do this
code1:
(or commandReactor
    (setq commandReactor (vlr-command-reactor nil
                    '((:vlr-unknownCommand . Test))
(defun Test (a b)
      (Setq x (read (car b)))
      (= (type x) 'INT)
      (< -1 x 251)
    (princ (itoa x))
cold2:
;反应器回调函数 用于判断和生成defun函数定义
(defun non_AutoMakeVbaFunc2(a b)
(setq b (car b)
c (non_string_to_list b ".")
d (substr (car c) 2 (- (strlen (car c)) (if (> (length c) 1) 1 2)))
e (substr b 2 (- (strlen b) 2))
f "fillet"
g "r"
h (cadr (non_string_to_list b "."))
h (substr h 1 (1- (strlen h)))
(if (or (= "APP" (strcase d))(= "THISDRAWING2" (strcase d))(= "app2" (strcase d))(= "r" (strcase d)))
(eval (read (strcat
"(defun "
d
"(command "
(vl-princ-to-string (vl-prin1-to-string f))
(vl-princ-to-string (vl-prin1-to-string g))
;"1"
h
"(command "
;字符串转表
(defun non_string_to_list(str del / lst)
(while (/= str (setq str (vl-string-subst "@" del str))))
(while (setq del (vl-string-position (ascii "@") str))
(setq del (substr str 1 del))
(setq str (vl-string-left-trim (strcat del) str))
(setq lst (append lst (list del)))
(setq str (substr str 2 (strlen str)))
    (append lst (list str))
;定义反应器用于判断当前发出的Lisp
(if (not AutoMakeVbaFunc_reactor2)
(setq AutoMakeVbaFunc_reactor2 (vlr-lisp-reactor nil '((:vlr-lispWillStart . non_AutoMakeVbaFunc2))))
attach is code from nonsmall
« Last Edit: July 21, 2014, 02:36:14 AM by haibinpro »
haibinpro
Re: How to make a reactor to enable rxxx commands.
« Reply #1 on: July 21, 2014, 02:41:48 AM »
 I have a confuse about the code
 the code below is work when use (app.3) (app.5)etc,but (r.3) (app2.7)is not works.why?
(setq b (car b)
f "fillet"
g "r"
(eval (read (strcat
"(defun "
d
"(command "
;"1"
h
"(command "
;字符串转表
;定义反应器用于判断当前发出的Lisp
Also there is a confuse about the recall function.
the recall function have a para name a.what is a explain for.any information about it is welcome.
(defun Test (a b)
(defun non_AutoMakeVbaFunc(a b)
« Reply #2 on: July 21, 2014, 12:32:24 PM »
This seems to work:
(if (null fillet:reactor)
    (setq fillet:reactor (vlr-command-reactor nil '((:vlr-unknowncommand . fillet:callback))))
(defun fillet:callback ( obj arg / rad )
    (if (and (wcmatch (setq arg (strcase (car arg))) "R#*")
             (setq rad (distof (substr arg 2)))
        (eval
            (vl-list* 'defun (read (strcat "c:" arg)) 'nil (list 'setvar ''filletrad rad)
                    (vl-cmdf "_.fillet")
                    (while (< 0 (getvar 'cmdactive)) (vl-cmdf "\\"))
(vl-load-com) (princ)
haibinpro
« Reply #3 on: July 22, 2014, 03:18:11 AM »
Thanks Mr Lee.
It works sometime,but mostly not works,seems my computer's problem.
I'll try reinstall autocad to fix it.
命令: r2 ; 错误: 出现异常: 0xC0000005 (访问冲突)
; 警告: 忽略展开 异常
未知命令“R2”。按 F1 查看帮助。
命令: R2 ; 错误: ads_undef 失败: <名称 编号 资源>: C:R2 2947 22
未知命令“R2”。按 F1 查看帮助。
roy_043
  • BricsCAD 18
« Reply #4 on: July 23, 2014, 05:03:42 AM »
I was trying to improve fillet:callback so that it would run the newly created function.
To my surprise only the first piece of code works (insert code before the final princ statement).
Note: I use BricsCAD.
(eval (read (strcat "(c:" arg ")")))
(vla-sendcommand (vla-get-activedocument (vlax-get-acad-object)) " ")
(vla-sendcommand (vla-get-activedocument (vlax-get-acad-object)) (strcat arg " "))
(vla-sendcommand (vla-get-activedocument (vlax-get-acad-object)) (strcat "(c:" arg ") "))
« Reply #5 on: July 23, 2014, 09:03:13 AM »
If you can live with an extra key stroke, this will work without a reactor.
[borrowed a little code from Lee :)]
  1. (defun c:mf (/ fr)
  2.   (if (and (setq fr (getstring "\nEnter fillet distance. "))
  3.            fr (not (zerop (atof fr))))
  4.     (progn
  5.       (eval
  6.         (vl-list* 'defun
  7.                   (read (strcat "c:r" fr)) 'nil (list 'setvar ''filletrad (atof fr))
  8.                   '((vl-cmdf "_.fillet")
  9.                     (while (< 0 (getvar 'cmdactive)) (vl-cmdf "\\"))
  10.                     (princ)
  11.                    )
  12.         )
  13.       )
  14.       (princ (strcat "\nCommand R" fr " created"))
  15.     )
  16.     (princ "\nFailed to create a command.")
  17.   )
  18.   (princ)
  19. )
« Reply #6 on: July 23, 2014, 05:34:54 PM »
Feel free to modify the code as you see fit!
In my brief tests, the defined function was automatically being evaluated following evaluation of the callback function, as I too initially thought vla-sendcommand would be required within the callback function.
haibinpro
« Reply #7 on: July 23, 2014, 08:34:59 PM »
  4.     (progn
  5.       (eval
  6.         (vl-list* 'defun
  10.                     (princ)
  11.                    )
  12.         )
  13.       )
  15.     )
  17.   )
  18.   (princ)
  19. )
Works fine.the only problem is this.
command: mf
Enter fillet distance. 5.5
Command R5.5 created
command:
command: r5
command: dra DIMRADIUS
mf a fillet 5.5 command,but it only can use by r5 but not r5.5.the messenger"Command R5.5 created"is not correct.
another thing.
command: mf
Enter fillet distance. dsa
command:
command:  MF
Enter fillet distance. 3r
Command R3r created
command:
command: r3r
atof Function
Converts a string into a real number
(atof string)
Arguments
string
A string to be converted into a real number.
Return Values
A real number.
command: (atof "r3r")
0.0
command: (atof "3")
3.0
« Last Edit: July 23, 2014, 08:38:48 PM by haibinpro »
« Reply #8 on: July 23, 2014, 11:29:13 PM »
Yes decimal points are not allowed in function names. No way around that that I see.
Strings in the radius like 3r can be trapped. And this will do that
    (defun c:mf (/ fr)
              (not (wcmatch fr "*[~0123456789.]*")))
       (progn ........
Back to your fractions, like 5.5
The only way I see to deal with it is to create a routine like this, that starts and waits for the radius.
Enter fc <space> or <enter> then the 5.5 <enter>
  1. (defun c:fc (/ fr) ; not sure the FC short cut is being used by ACAD
  3.            fr
  4.            (not (zerop (atof fr)))
  5.            (not (wcmatch fr "*[~0123456789.]*"))
  6.       )
  7.     (progn
  8.       (setvar "filletrad" (atof fr))
  9.       (vl-cmdf "_.fillet")
  10.       (while (< 0 (getvar 'cmdactive)) (vl-cmdf "\\"))
  11.       (princ)
  12.     )
  13.     (princ "\nInvalid radius.")
  14.   )
  15.   (princ)
  16. )
