Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
.NET
Topic:
Open Options Dialog to specific tab
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Open Options Dialog to specific tab (Read 2204 times)
Keith Brown
Swamp Rat
on:
July 19, 2014, 09:18:45 AM »
Does anyone know if it is possible using the .net api to open up the options dialog to a specific tab? I have created a program that inserts a tab into this dialog and it would be nice to be able to create a program specific settings command that opens up this dialog to the specified tab.
Logged
Keith Brown
AutoCAD MEP Blog
RSS Feed
Andrey Bushman
Swamp Rat
Re: Open Options Dialog to specific tab
Reply #1 on:
July 19, 2014, 01:57:05 PM »
This question is interesting for me too, but I have not found solution in past.
Logged
King Gator
C3D user & customizer
Reply #2 on:
July 19, 2014, 02:45:08 PM »
Code - C#:
[Select]
Autodesk
AutoCAD
Internal
Utils
InvokeOptionsDialog
"System"
false
0
false
Replace "System" with your tab name.
Logged
LE3
Guest
Reply #3 on:
July 19, 2014, 02:47:43 PM »
how about using acedCmd pinvoke or any newer approach than this now avail and +OPTIONS and then just pass the desired tab index.
Command: +OPTIONS
Tab index <0>: 3
See if works for you.
Oh... I see Jeff posted some method for this, cool.
Logged
Keith Brown
Swamp Rat
Reply #4 on:
July 19, 2014, 02:50:13 PM »
Thanks Jeff, works great.
Le, that only works if you know the tab index. For custom tabs it will be impossible to know the index. How do you know how many custom tabs the user has?
Logged
Keith Brown
AutoCAD MEP Blog
RSS Feed
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
.NET
Topic:
