Author Topic: flat pattern in AutoCAD  (Read 2683 times)
Bethrine
« on: July 18, 2014, 12:52:58 PM »
Will AutoCAD create a flat pattern from a bent part for you? If so, how?  :?
Bethrine
Re: flat pattern in AutoCAD
« Reply #1 on: July 18, 2014, 01:51:50 PM »
Okay, I opened in Inventor and created a flat pattern there. Now I need to get that flat pattern into AutoCAD. I can dimension and draw it but I would like to just open or import it. If anyone knows how to do this it would be much appreciated!
(Inventor provides a good educated guess when it creates flat patterns as opposed to my guessing at them.)
Matt__W
  • I like my water diluted.
« Reply #2 on: July 18, 2014, 02:00:06 PM »
Inventor can't export to DWG or DXF??
Google found this for me....
http://forums.autodesk.com/t5/Inventor-General/Inventor-Drawings-to-AutoCAD/m-p/3118738#M409886
Autodesk Expert Elite
Bethrine
« Reply #3 on: July 18, 2014, 02:03:30 PM »
Of course it can! You just don't get the flat pattern.  :| My co-worker unfolded the part and exported and that worked. I also found that you can export the flat pattern sketch to .dxf
Jochen
« Reply #4 on: July 18, 2014, 02:26:26 PM »
You can do the complete process in AutoCad too,
see
www.ant-ares.de
regards
Jochen
Bethrine
« Reply #5 on: July 18, 2014, 03:41:09 PM »
Unfortunately, I don't speak that language  :-(. Also, I think that is in 2015? I don't have 2015. I typed the command in the command line and AutoCAD didn't recognize it.
