Author Topic: How to get "dwgname" properly  (Read 2821 times)
MeasureUp
« on: July 16, 2014, 07:31:56 PM »
In my code, there are two lines:
(vl-file-size (getvar "dwgname"))
It works fine until today...
The 2nd line now returns a "nil" instead of a file size.
I now find that I have to rewrite the 2nd line to this:
(vl-file-size (strcat (getvar 'DwgPrefix) (getvar "dwgname")))
I test this code by using
1) the same drawing file,
2) same location,
3) same PC,
4) same AutoCAD version (Mech 2014)
And there is no setup changes on my pc or AutoCAD.
The only difference is the time, it works find yesterday, but today.
All my other codes are loaded and work perfectly.
Your helps are much appreciated.
Re: How to get "dwgname" properly
« Reply #1 on: July 16, 2014, 08:57:00 PM »
Does this work?
(vl-file-size (vla-get-fullname (vla-get-ActiveDocument (vlax-get-acad-object))))
Gasty
« Reply #2 on: July 16, 2014, 09:40:21 PM »
This should work too:
(vl-file-size (findfile(getvar "dwgname")))
Gaston Nunez
MeasureUp
« Reply #3 on: July 17, 2014, 01:12:03 AM »
Thanks to CAB & Gasty. Your codes work perfectly.
Actually my 2nd question was that why my code (shown below) worked OK previously and why today there is a problem:
Thanks.
kpblc
« Reply #4 on: July 17, 2014, 01:18:20 AM »
I think vl-file-size returns nil only if file exists and is read-only (by file attributes; not by access rights). You can try to copy your dwg to your %TEMP% folder and get filesize from copy.
Sorry for my English.
MeasureUp
« Reply #5 on: July 17, 2014, 01:49:56 AM »
Thanks for your reply.
The drawing file which I was referring to is fully accessible (it is not set to "read-only") and is in "C:\Users\MyName\Documents\".
To me, it should not be a problem - I can't figure it out.
« Reply #6 on: July 17, 2014, 08:38:33 AM »
Gaston Nunez
Some caution here, if you have another file with the same name ACAD search may find it first & report unwanted information.
dgorsman
« Reply #7 on: July 17, 2014, 10:20:21 AM »
Doesn't (findfile ...) check in the folder of the active drawing first?  If so, then since there are unique file name constraints inside folders the active drawing file is the *only* one which can be found.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
« Reply #8 on: July 17, 2014, 10:35:24 AM »
I believe you are correct 8) I stand corrected.
« Reply #9 on: July 17, 2014, 01:23:29 PM »
The vl-file-size function does not perform in the same way as the findfile function when supplied with a filename without a filepath, as stated in the documentation:
If you do not specify a full path name, vl-file-size searches the AutoCAD default drawing directory for the file.
The default drawing directory is not necessary equal to the working directory (DWGPREFIX); the default drawing directory is usually the My Documents folder.
MeasureUp
« Reply #10 on: July 17, 2014, 10:47:38 PM »
Before looking to your replies I think I got into another problem:
When I loaded this code today I found there is a problem with this line:
(getenv 'computername)It returns a message of "; error: bad argument type: stringp COMPUTERNAME"
I simply paste the above line to the command line and I get the same result.
Again, it works fine all time but today!
It now only works when it is rewritten as:
(getenv "computername")
What is wrong?
PS. I think the answer to this may also solve all my questions in this thread.
« Last Edit: July 18, 2014, 12:01:44 AM by MeasureUp »
Gasty
« Reply #11 on: July 18, 2014, 12:54:01 AM »
As the doc says, the argument for getenv and getvar it's a string, so the correct way to call them it's:
(getenv "EnvVar") ; Enviroment variables are usually case sensitive, so take care of that
As for getvar, you can use a quoted system variable name like (getvar 'DWGPREFIX) or a string literal like (getvar "DWGPREFIX") Autocad sys vars are not case sensitive. My preference goes to the last as a quote have a special meaning in lisp. and in Autocad means transparent command.
Gaston Nunez
MeasureUp
« Reply #12 on: July 25, 2014, 01:53:02 AM »
Thanks to everyone's help for getting the file path. I was too busy this week... just have done a project GA drawing.
I forgot that the Enviroment variables are case sensitive.
As Gaston seggusted, I will use double quote for both of S.V. and E.V.
Cheers!
