Author Topic: open drawings list box  (Read 6116 times)
Re: open drawings list box
« Reply #15 on: July 16, 2014, 10:41:30 AM »
Had few minutes today to write this routine and saved it to my Toolbox .  ;)
Nice but perhaps the dialog box width should be dynamic.
Keith Brown
« Reply #16 on: July 16, 2014, 10:53:18 AM »
I set my Taskbar variable to 1 so that each open drawing will show up as a separate window on the taskbar.
Tharwat
  • Hypersensitive
« Reply #17 on: July 16, 2014, 10:58:55 AM »
Thank you CAB , codes updated to be dynamic with the width .
pedroantonio
« Reply #18 on: July 16, 2014, 02:13:45 PM »
nice job Tharwat but my paths of dwg is still be to big. I use your updated code but i still have problem. Can you help
jbuzbee
« Reply #19 on: July 16, 2014, 02:20:48 PM »
Attached is an OpenDCL version.  You must have the OPenDCL Runtime installed.  This is a sample program:
AutoCAD palette with drawing preview
Commands_DwgManager.lsp updated to include (command "OpenDCL") call.
« Last Edit: July 18, 2014, 08:20:47 AM by jbuzbee »
James Buzbee
Windows 8
pedroantonio
« Reply #20 on: July 16, 2014, 02:26:36 PM »
hi jbuzbee .This files is not working to my autocad. I dont have open dcl and i dont use it. Can you update Tharwat code
« Reply #21 on: July 16, 2014, 02:41:51 PM »
Because I'm bored here you go, but you really need to start trying to learn some of this stuff.....
(defun c:dwgs (/ *error* dlg f i id lst nm obj w x)
  ;; Tharwat 16.June.2014 ;;
  ;; Cycle through drawings ;;
  (defun *error* (msg)
    (if (and dlg (setq dlg (findfile dlg)))
      (vl-file-delete dlg)
    (if (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*")
      (princ msg)
      (princ (strcat "\n ** Error : " msg " **"))
  (setq obj (vlax-get-acad-object))
  (vlax-for dwg (vla-get-documents obj)
    (if (and (/= "" (setq nm (vla-get-name dwg))) (not (eq (getvar 'dwgname) nm)))
      (setq lst (cons (cons nm dwg) lst))
  (if lst
      (setq w (apply 'max (mapcar '(lambda (x) (strlen x)) (mapcar 'car lst))))
      (if (and (setq dlg (vl-filename-mktemp nil nil ".dcl")) (setq f (open dlg "w")))
  (write-line
    (strcat
      "test : dialog { label = \"All opened drawings\"; width ="
      (if (> w 90)
"90"
(itoa (+ 2 w))
      ;; RJP mod allow_accept
      ": list_box { label = \"Opened drawings\"; key = \"dwgs\"; height = 16; allow_accept = true;}"
      ": row { alignment = centered; fixed_width = true;"
      ": button { label = \"Okay\"; key = \"oki\"; is_default = true; width = 10;}"
      ": button { label = \"Exit\"; key = \"esc\"; is_cancel = true; width = 10; }}}"
    f
  (close f)
(alert "Can't load the temporary file <!>")
      (if (not (new_dialog "test" (setq id (load_dialog dlg)) ""))
(progn (if (>= id 0)
(unload_dialog id)
(progn (start_list "dwgs")
       (mapcar 'add_list (mapcar 'car lst))
       (end_list)
       (set_tile "dwgs" "0")
       (action_tile "oki" "(setq i (atoi (get_tile \"dwgs\")))(done_dialog)")
       (action_tile "esc" "(done_dialog)")
       (start_dialog)
       (unload_dialog id)
      ;; RJP mod to use vla-activate
      (and i (vla-activate (nth i (mapcar 'cdr lst))))
    (alert "No opened named drawings to cycle through !!")
« Last Edit: July 16, 2014, 03:39:13 PM by ronjonp »
pedroantonio
« Reply #22 on: July 16, 2014, 02:46:57 PM »
Thank you ronjonp
snownut2
  • Bricscad 22 Ultimate
« Reply #23 on: July 16, 2014, 02:56:09 PM »
Don't hold your breath....
« Reply #24 on: July 16, 2014, 03:14:14 PM »
I'm not... :P
Tharwat
  • Hypersensitive
« Reply #25 on: July 16, 2014, 03:21:01 PM »
Thank you ron for the adds , nicely done .
I have seen the last request from the OP but I had to have my shower before I come back to it .  :lol:
Regards .
