Author Topic: open drawings list box  (Read 6217 times)
pedroantonio
« on: July 15, 2014, 11:52:06 AM »
is it possible to manage open drawings with a lost box lisp? if i have 10 open drawings in my autocad i have to go to window menu and select which drawing i want to use.Is it possible to display the names of the open drawings in a list box with an OK button and sellect any time the drawings i whant to use ?
Sorry for my bad English
Thanks ....
Re: open drawings list box
« Reply #1 on: July 15, 2014, 12:45:16 PM »
On the Main menu Bar ; Select window. ( between Modify and Help on my menu)
If the file you want is not in the list, select More Windows ...
or Alt+W+M
« Reply #2 on: July 15, 2014, 12:58:08 PM »
Or use the various window controls located on the User Interface panel of the View tab:
« Reply #3 on: July 15, 2014, 01:36:33 PM »
Or cycle with ctrl+tab.
« Reply #4 on: July 15, 2014, 01:48:39 PM »
I cycle  8)
Program the mouse side buttons for forward & back one drawing.
pedroantonio
« Reply #5 on: July 15, 2014, 01:54:59 PM »
dgorsman
« Reply #6 on: July 15, 2014, 02:41:54 PM »
2015 has extra tabs, similar to layouts, but for drawing files.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
pedroantonio
« Reply #7 on: July 15, 2014, 03:06:43 PM »
i am using Autocad 2010
V-Man
kraz
« Reply #9 on: July 15, 2014, 09:53:35 PM »
Maybe, You want this one...
since acad 2012? or 2013, autocad has filetab function.
I had used bellow arx tool and is very nice...
download and rename the file name:: "iDwgTab2.0.0.6.renameTozip -> iDwgTab2.0.0.6.zip"
http://pds25.egloos.com/pds/201405/16/51/iDwgTab2.0.0.6.renameTozip
« Reply #10 on: July 15, 2014, 11:02:02 PM »
KRAZ
Bad link for me, I get
403 - Forbidden
kraz
« Reply #11 on: July 16, 2014, 07:57:37 AM »
KRAZ
403 - Forbidden
hmm...
attached the file...
this arx from http://arx119.egloos.com/
Tharwat
  • Hypersensitive
« Reply #12 on: July 16, 2014, 09:17:50 AM »
Had few minutes today to write this routine and saved it to my Toolbox .  :wink:
  1. (defun c:dwgs (/ *error* f id lst v dlg nm i obj cn w)
  2.   ;;    Tharwat 16.June.2014            ;;
  3.   ;; Cycle through drawings             ;;
  4.   (defun *error* (msg)
  5.     (if (and dlg (setq dlg (findfile dlg)))
  6.       (vl-file-delete dlg)
  7.     )
  8.     (if (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*")
  9.       (princ msg)
  10.       (princ (strcat "\n ** Error : " msg " **"))
  11.     )
  12.   )
  13.   (setq cn
  14.          (vla-get-fullname
  15.          )
  16.   )
  17.     (if (and (/= "" (setq nm (vla-get-fullname dwg)))
  18.              (not (eq cn nm))
  19.         )
  20.       (setq lst (cons nm lst))
  21.     )
  22.   )
  23.   (if lst
  24.     (progn
  25.       (setq w (apply 'max (mapcar '(lambda (x) (strlen x)) lst)))
  26.       (if (and (setq dlg (vl-filename-mktemp nil nil ".dcl"))
  27.                (setq f (open dlg "w"))
  28.           )
  29.         (progn
  30.           (write-line
  31.             (strcat
  32.               "test : dialog { label = \"All opened drawings\"; width ="
  33.               (if (> w 90)
  34.                 "90"
  35.                 (itoa (+ 2 w))
  36.               )
  37.               ";"
  38.               ": list_box { label = \"Opened drawings\"; key = \"dwgs\"; height = 16;}"
  39.               ": row { alignment = centered; fixed_width = true;"
  40.               ": button { label = \"Okay\"; key = \"oki\"; is_default = true; width = 10;}"
  41.               ": button { label = \"Exit\"; key = \"esc\"; is_cancel = true; width = 10; }}}"
  42.             )
  43.             f
  44.           )
  45.           (close f)
  46.         )
  47.         (alert "Can't load the temporary file <!>")
  48.       )
  49.       (if (not (new_dialog
  50.                  "test"
  51.                  (setq id (load_dialog dlg))
  52.                  ""
  53.                )
  54.           )
  55.         (progn (if (>= id 0)
  56.                  (unload_dialog id)
  57.                )
  58.                (if (and dlg (setq dlg (findfile dlg)))
  59.                  (vl-file-delete dlg)
  60.                )
  61.         )
  62.         (progn
  63.           (start_list "dwgs")
  64.           (mapcar 'add_list lst)
  65.           (end_list)
  66.           (set_tile "dwgs" "0")
  67.           (action_tile
  68.             "oki"
  69.             "(setq i (atoi (get_tile \"dwgs\")))(done_dialog)"
  70.           )
  71.           (action_tile "esc" "(done_dialog)")
  72.           (start_dialog)
  73.           (unload_dialog id)
  74.           (vl-file-delete dlg)
  75.         )
  76.       )
  77.       (if i
  78.         (vlax-for x (vla-get-documents obj)
  79.           (if (eq (vla-get-fullname x) (nth i lst))
  80.             (vla-put-windowstate x acMax)
  81.             (vla-put-windowstate x acMin)
  82.           )
  83.         )
  84.       )
  85.     )
  86.     (alert "No opened named drawings to cycle through !!")
  87.   )
  88.   (princ)
  89. )
  90.
« Last Edit: July 16, 2014, 10:56:42 AM by Tharwat »
GDF
« Reply #13 on: July 16, 2014, 10:07:55 AM »
Nice one Tharwat. This one by:
;;; Written By Peter Jamtgaard Copyright April 2003
;;; Activate drawing dialog control program that uses a tree structure for
;;; display of the filenames
I like the tree structure. I will need to get permission to post his routine. The routine uses Visual Basic which is no longer installed with AutoCAD.
Tharwat
  • Hypersensitive
« Reply #14 on: July 16, 2014, 10:30:04 AM »
Nice one Tharwat.
Thank you for the feed back GDF and I am happy that you like it :-)
