Author Topic: True Colour help  (Read 2239 times)
ROBBO
True Colour help
« on: July 15, 2014, 06:28:14 AM »
  1. (vla-put-TextColor (vlax-ename->vla-object e) acMagenta)
Although I can achieve the magenta colour for text as shown in the line above, but I would like to achieve the true colour 255,0,255.
I have tried, but failed. Any help or suggestions to achieve this goal would be much appreciated.
Kind regards, Robbo.
The only thing to do with good advice is to pass it on.
It is never of any use to oneself.
Oscar Wilde
(1854-1900, Irish playwright, poet and writer)
ChrisCarlson
Re: True Colour help
« Reply #1 on: July 15, 2014, 07:41:08 AM »
Do you want true color or RGB? The property you listed is RGB format
//doh! had mixed up different programs, disregard above
I'd peruse Lee's site
http://lee-mac.com/colourconversion.html
tombu
  • ByLayer=>Not0
« Reply #2 on: July 15, 2014, 08:39:35 AM »
Google acad_truecolordlg, for an object to be true color the DXF code 420 needs to be set.  I've attached a lisp for modifying attributes including color as an example.
Tom Beauford P.S.M.
« Reply #3 on: July 15, 2014, 09:51:34 AM »
Have a play
  1. (defun c:doit (/ add stuff here)
  2.                  (vlax-get-acad-object)
  3.                  (strcat "AutoCAD.AcCmColor." (substr (getvar "acadver") 1 2))
  4.                )
  5.   )
  6.   (vla-setrgb colObj 255 0 255)
  7.   (setq thingy (car (entsel)))
  8.   (vla-put-truecolor (vlax-ename->vla-object thingy) colObj)
  9. )
ROBBO
« Reply #4 on: July 15, 2014, 10:33:28 AM »
Thanks all for the info. Will read up and have a play.
Oscar Wilde
ROBBO
« Reply #5 on: July 16, 2014, 02:56:29 AM »
Had a go. Although I had some success. Was unable to change a text colour value within a dimension. Nevertheless have learned something and appreciated the help and advice above.
Kind regards, Robbo
Oscar Wilde
« Reply #6 on: July 16, 2014, 03:33:40 AM »
Ahhhh ..
http://help.autodesk.com/view/ACD/2015/ENU/?guid=GUID-36320A64-4513-4249-9FF0-ECF19C0B6EC1
TextColor Property (ActiveX)
Specifies the color of the text for dimension and tolerance objects.
>>> Colors can be set and read as numeric index values ranging from 0 to 256. Constants have been provided for the standard seven colors, as well as the BYBLOCK and BYLAYER designations. <<<
