Author Topic: VB.NET not MENULOAD from Initialize  (Read 2365 times)
FELIX
« on: July 08, 2014, 10:46:15 PM »
The MENULOAD at startup does not work and shows ERROR. Already run the TESTE command Works.
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.Interop
Imports Autodesk.AutoCAD.EditorInput
Imports System
 Namespace APPTESTENAME
    Public Class Initialization
        Implements IExtensionApplication
        Public Sub Initialize() Implements IExtensionApplication.Initialize
            MsgBox("START OK")
            Try
                   Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
                Dim LINHA As String
                LINHA = "(IF (NOT (MENUGROUP ""TOPOCAD2000"")) (PROGN(COMMAND ""_MENULOAD"" ""TOPOCAD2000"")(MENUCMD ""P15=+TOPOCAD2000.POP1""))(ALERT ""\nMENU ALREADY LOADED"") ) "
                  acDoc.SendStringToExecute(LINHA, True, False, False)
              Catch
                  MsgBox("ERRO")
              End Try
          End Sub
          Public Sub Terminate() Implements IExtensionApplication.Terminate
          End Sub
      End Class
      Public Class COMANDOS
          <CommandMethod("TESTE")> _
          Public Sub Teste()
              Dim LINHA As String
          End Sub
      End Class
  End Namespace
OK.
WILL HATCH
Re: VB.NET not MENULOAD from Initialize
« Reply #1 on: July 09, 2014, 12:01:47 AM »
Me no VB but in c# we inherit at the start of the class and then override the methods of initialize and terminate
Edit: This is the case I think
http://msdn.microsoft.com/en-us/library/818x9db9(v=vs.90).aspx
« Last Edit: July 09, 2014, 12:08:15 AM by WILL HATCH »
nekitip
« Reply #2 on: July 09, 2014, 03:56:36 AM »
do you have your MdiActiveDocument at the time of init?
(is any document loaded at all?)
FELIX
« Reply #3 on: July 09, 2014, 09:51:23 AM »
The command is executed when AutoCAD is opened.
OK.
dgorsman
« Reply #4 on: July 09, 2014, 12:46:09 PM »
Hasn't MENULOAD been obsolete for several versions, replaced with CUILOAD?
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
huiz
  • Certified Prof C3D
« Reply #5 on: July 09, 2014, 01:50:44 PM »
You could try to catch the error and show that. Though I thought errors while initializing are silently handled, so I am surprised you see the error messagebox.
I think the document is not loaded yet, so you can not send commands to the commandline.
