Author Topic: Importing Layer controls without opening drawings  (Read 10162 times)
MSTG007
« on: July 08, 2014, 01:46:24 PM »
I was wondering if there is a possible way for a user to select certain drawings within the same directory (folder) and inject a new layer with its color without the user having to physically open each drawing and creating them?
Civil3D 2020
Re: Importing Layer controls without opening drawings
« Reply #1 on: July 08, 2014, 01:52:14 PM »
Download & load my ObjectDBX Wrapper function & Get Files Dialog function, and then try the following code:
  1. (defun c:test ( / lst )
  2.     (if (setq lst (LM:getfiles "Select drawings to process" "" "dwg;dwt;dws"))
  3.         (LM:odbx '(lambda ( doc ) (vla-put-color (vla-add (vla-get-layers doc) "MyLayer") acred)) lst t)
  4.     )
  5.     (princ)
  6. )
The above will create a red layer called "MyLayer" in selected drawings, or will make this layer red if it already exists.
MSTG007
« Reply #2 on: July 08, 2014, 02:01:17 PM »
Geesh! Wow! I have a user who is not very tech savvy. How can I get them to use this?
Civil3D 2020
« Reply #3 on: July 08, 2014, 02:02:18 PM »
Show them how to use it?
MSTG007
« Reply #4 on: July 08, 2014, 02:05:15 PM »
I can definitely try too. I guess I was thinking that there would be a way that the user can launch the command, pops up a box to select what files and then prompt what layer name and color to use.
Civil3D 2020
« Reply #5 on: July 08, 2014, 02:12:10 PM »
Yes, this is possible -
  1. (defun c:test ( / col lay lst )
  2.     (while (not (or (= "" (setq lay (getstring t "\nSpecify layer name: "))) (snvalid lay)))
  3.         (princ "\nInvalid layer name.")
  4.     )
  5.     (if (and (/= "" lay)
  6.              (setq col (acad_colordlg 7 nil))
  7.              (setq lst (LM:getfiles "Select drawings to process" "" "dwg;dwt;dws"))
  8.         )
  9.         (LM:odbx '(lambda ( doc ) (vla-put-color (vla-add (vla-get-layers doc) lay) col)) lst t)
  10.     )
  11.     (princ)
  12. )
MSTG007
« Reply #6 on: July 08, 2014, 02:44:52 PM »
I will give it a try!
Civil3D 2020
MSTG007
« Reply #7 on: July 08, 2014, 04:14:44 PM »
Ok. I am having a problem. I can not figure out how to run your lisp! lol (sorry)!
Civil3D 2020
irneb
« Reply #8 on: July 09, 2014, 01:59:37 AM »
Did you do this also?
Download & load my ObjectDBX Wrapper function & Get Files Dialog function...
You'd need both those in addition to Lee's code, since it's calling those 2 functions. Thus you'd have to load those functions as well, or simply paste all of them into the same LSP file.
HasanCAD
« Reply #9 on: July 09, 2014, 03:17:19 AM »
Find attached
duotu007
« Reply #10 on: July 10, 2014, 04:13:33 AM »
  4.     )
  8.         )
  10.     )
  11.     (princ)
  12. )
hi,LM,some fun like vla-purgeall  vla-zoomextents can't work with ObjectDBX?
MSTG007
« Reply #11 on: July 10, 2014, 07:30:26 AM »
Thank you all for your help! Just another dumb question to go with this... Is there a way to run another lisp inside or script file? If not that's ok. Just curious!
Civil3D 2020
« Reply #12 on: July 10, 2014, 07:40:20 AM »
yes. just load it from the scoipt and call it.
Have a play.
« Reply #13 on: July 10, 2014, 01:38:16 PM »
@Irné & Hasan, thank you for assisting in my absence.  :-)
@duotu007, only ActiveX methods derived from the document object will be available from ObjectDBX, and even then there are limitations. Since zoomextents is a method of the application, this certainly cannot be used, but I have not tried the purgeall method through an ObjectDBX interface - let me know how you get on.  ;-)
MSTG007
« Reply #14 on: July 10, 2014, 01:45:40 PM »
  4.     )
  8.         )
  10.     )
  11.     (princ)
  12. )
I have been working on this for a few... no such luck with calling a script. However, this is pretty powerful stuff!:)
The script is on my C root drive...
Civil3D 2020
« Reply #15 on: July 10, 2014, 01:51:03 PM »
Are you unable to run the program?
Note that my program is utilising ObjectDBX to batch process all selected drawings, no AutoCAD Script (.scr) is necessary.
MSTG007
« Reply #16 on: July 10, 2014, 01:54:42 PM »
your program runs great and opens! I have a script file I was seeing if I could run it.
Civil3D 2020
« Reply #17 on: July 10, 2014, 02:26:54 PM »
What are you attempting to use the script file for?
MSTG007
« Reply #18 on: July 10, 2014, 02:30:53 PM »
Built kinda with the first request with the layers. What you provided above was; a way to add revision layers to a bunch of dwgs at the same time. So as it prompts for the layer name and color. (Layer name REVISION1, Color 4), next revision would happen (Layer name REVISION2, Color 4), but change (Layer name REVISION1, to color 9), and so forth with as many revisions there may need. so the Color 4 is bold and the color 9 I screened back.
Civil3D 2020
« Reply #19 on: July 10, 2014, 02:37:52 PM »
So presumably you would incorporate the additional operations to switch REVISION1 to colour 9 into the program I have provided - i.e. into the function argument passed to the LM:odbx function.
I am not sure if you have taken the operations from the code I have provided to use in a Script, or are attempting to call the program I have provided through a Script, but either way, a Script is not required.
MSTG007
« Reply #20 on: July 10, 2014, 02:41:18 PM »
Yes you are right. For me it was easier to code it under the script I do not completely understand how you the operations of your program. lol. I am trying though! lol. But as you stated above yes that is what I would like to do.
Civil3D 2020
« Reply #21 on: July 10, 2014, 02:53:57 PM »
OK - The following code should get you off to a good start:
  1. (defun c:test ( / lay lst nco new oco old )
  2.     (while (not (or (= "" (setq new (getstring t "\nSpecify new layer name <skip>: "))) (snvalid lay)))
  4.     )
  5.     (if (or (= "" new) (setq nco (acad_colordlg 7 nil)))
  6.         (progn
  7.             (while (not (or (= "" (setq old (getstring t "\nSpecify old layer name <skip>: "))) (snvalid lay)))
  8.                 (princ "\nInvalid layer name.")
  9.             )
  10.             (if (or (= "" old) (setq oco (acad_colordlg 7 nil)))
  11.                 (if (setq lst (LM:getfiles "Select drawings to process" "" "dwg;dwt;dws"))
  12.                     (LM:odbx
  13.                        '(lambda ( doc / lay )
  14.                             (if (/= "" new)
  15.                                 (vla-put-color (vla-add (vla-get-layers doc) new) nco)
  16.                             )
  17.                             (if (and (/= "" old)
  18.                                     (not
  19.                                         (vl-catch-all-error-p
  20.                                             (setq lay
  21.                                                 (vl-catch-all-apply 'vla-item
  22.                                                     (list (vla-get-layers doc) old)
  23.                                                 )
  24.                                             )
  25.                                         )
  26.                                     )
  27.                                 )
  28.                                 (vla-put-color lay oco)
  29.                             )
  30.                         )
  31.                         lst t
  32.                     )
  33.                 )
  34.             )
  35.         )
  36.     )
  37.     (princ)
  38. )
MSTG007
« Reply #22 on: July 10, 2014, 03:04:24 PM »
Wow Sweet! Thank you.
Civil3D 2020
MSTG007
« Reply #23 on: July 10, 2014, 03:17:19 PM »
Well, I did get a chance to look at it. The following code is what I tried to put together into one lisp like they suggested above.
                    (LM:odbx
                            (if (/= "" new)
                                    (not
                                           (setq lay
                        lst t
;;------------------=={ Get Files Dialog }==------------------;;
;;  An analog of the 'getfiled' function for multiple files.  ;;
;;  Author: Lee Mac, Copyright © 2013 - www.lee-mac.com       ;;
;;  Arguments:                                                ;;
;;  msg - Dialog box label; 'Select Files' if nil or "".      ;;
;;  def - Default directory; dwgprefix if nil or "".          ;;
;;  ext - File extension filter (e.g. "dwg;lsp"); "*" if nil  ;;
;;  Returns:  List of selected files, else nil                ;;
;;  Version 1.3    -    25-07-2013                            ;;
(defun LM:getfiles ( msg def ext / *error* dch dcl des dir dirdata lst rtn )
    (defun *error* ( msg )
        (if (= 'file (type des))
            (close des)
        (if (and (= 'int (type dch)) (< 0 dch))
            (unload_dialog dch)
        (if (and (= 'str (type dcl)) (findfile dcl))
            (vl-file-delete dcl)
        (if (and msg (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*")))
            (princ (strcat "\nError: " msg))
        (and
            (setq dcl (vl-filename-mktemp nil nil ".dcl"))
            (setq des (open dcl "w"))
                (foreach x
                        "lst : list_box"
                        "    width = 40.0;"
                        "    height = 20.0;"
                        "    fixed_width = true;"
                        "    fixed_height = true;"
                        "    alignment = centered;"
                        "    multiple_select = true;"
                        "but : button"
                        "    width = 20.0;"
                        "    height = 1.8;"
                        "getfiles : dialog"
                        "    key = \"title\"; spacer;"
                        "    : row"
                        "        : edit_box { key = \"dir\"; label = \"Folder:\"; }"
                        "        : button"
                        "            key = \"brw\";"
                        "            label = \"Browse\";"
                        "    spacer;"
                        "    : row"
                        "        : column"
                        "            : lst { key = \"box1\"; }"
                        "            : but { key = \"add\" ; label = \"Add Files\"; }"
                        "        : column {"
                        "            : lst { key = \"box2\"; }"
                        "            : but { key = \"del\" ; label = \"Remove Files\"; }"
                        "    spacer; ok_cancel;"
                    (write-line x des)
                (setq des (close des))
                (< 0 (setq dch (load_dialog dcl)))
            (new_dialog "getfiles" dch)
            (setq ext (if ext (LM:getfiles:str->lst (strcase ext) ";") '("*")))
            (set_tile "title" (if (member msg '(nil "")) "Select Files" msg))
            (set_tile "dir"
                (setq dir
                    (LM:getfiles:fixdir
                        (if (or (member def '(nil "")) (not (vl-file-directory-p (LM:getfiles:fixdir def))))
                            (getvar 'dwgprefix)
                            def
            (setq lst (LM:getfiles:updatefilelist dir ext nil))
            (mode_tile "add" 1)
            (mode_tile "del" 1)
            (action_tile "brw"
                (vl-prin1-to-string
                   '(if (setq tmp (LM:getfiles:browseforfolder "" nil 512))
                        (setq lst (LM:getfiles:updatefilelist (set_tile "dir" (setq dir tmp)) ext rtn)
                              rtn (LM:getfiles:updateselected dir rtn)
            (action_tile "dir"
                (vl-prin1-to-string
                   '(if (= 1 $reason)
                        (setq lst (LM:getfiles:updatefilelist (set_tile "dir" (setq dir (LM:getfiles:fixdir $value))) ext rtn)
            (action_tile "box1"
                (vl-prin1-to-string
                        (lambda ( / itm tmp )
                            (if (setq itm (mapcar '(lambda ( n ) (nth n lst)) (read (strcat "(" $value ")"))))
                                (if (= 4 $reason)
                                        (   (equal '("..") itm)
                                            (setq lst (LM:getfiles:updatefilelist (set_tile "dir" (setq dir (LM:getfiles:updir dir))) ext rtn)
                                        (   (and
                                                (not (vl-filename-extension (car itm)))
                                                (vl-file-directory-p (setq tmp (LM:getfiles:checkredirect (strcat dir "\\" (car itm)))))
                                        (   (setq rtn (LM:getfiles:sort (append rtn (mapcar '(lambda ( x ) (strcat dir "\\" x)) itm)))
                                                  lst (LM:getfiles:updatefilelist dir ext rtn)
                                    (if (vl-some 'vl-filename-extension itm)
                                        (mode_tile "add" 0)
            (action_tile "box2"
                (vl-prin1-to-string
                        (lambda ( / itm )
                            (if (setq itm (mapcar '(lambda ( n ) (nth n rtn)) (read (strcat "(" $value ")"))))
                                (if (= 4 $reason)
                                    (setq rtn (LM:getfiles:updateselected dir (vl-remove (car itm) rtn))
                                    (mode_tile "del" 0)
            (action_tile "add"
                (vl-prin1-to-string
                        (lambda ( / itm )
                            (if (setq itm
                                    (vl-remove-if-not 'vl-filename-extension
                                        (mapcar '(lambda ( n ) (nth n lst)) (read (strcat "(" (get_tile "box1") ")")))
                            (mode_tile "add" 1)
                            (mode_tile "del" 1)
            (action_tile "del"
                (vl-prin1-to-string
                        (lambda ( / itm )
                            (if (setq itm (read (strcat "(" (get_tile "box2") ")")))
                                (setq rtn (LM:getfiles:updateselected dir (LM:getfiles:removeitems itm rtn))
                            (mode_tile "add" 1)
                            (mode_tile "del" 1)
            (if (zerop (start_dialog))
                (setq rtn nil)
    (*error* nil)
    rtn
(defun LM:getfiles:listbox ( key lst )
    (start_list key)
    (foreach x lst (add_list x))
    (end_list)
    lst
(defun LM:getfiles:listfiles ( dir ext lst )
    (vl-remove-if '(lambda ( x ) (member (strcat dir "\\" x) lst))
            (   (cdr (assoc dir dirdata)))
            (   (cdar
                    (setq dirdata
                        (cons
                            (cons dir
                                (append
                                    (LM:getfiles:sortlist (vl-remove "." (vl-directory-files dir nil -1)))
                                    (LM:getfiles:sort
                                        (if (member ext '(("") ("*")))
                                            (vl-directory-files dir nil 1)
                                            (vl-remove-if-not
                                                (function
                                                    (lambda ( x / e )
                                                        (and
                                                            (setq e (vl-filename-extension x))
                                                            (setq e (strcase (substr e 2)))
                                                            (vl-some '(lambda ( w ) (wcmatch e w)) ext)
                            dirdata
(defun LM:getfiles:checkredirect ( dir / itm pos )
        (   (vl-directory-files dir) dir)
        (   (and
                (=  (strcase (getenv "UserProfile"))
                    (strcase (substr dir 1 (setq pos (vl-string-position 92 dir nil t))))
                (setq itm
                    (cdr
                        (assoc (substr (strcase dir t) (+ pos 2))
                                ("my documents" . "Documents")
                                ("my pictures"  . "Pictures")
                                ("my videos"    . "Videos")
                                ("my music"     . "Music")
                (vl-file-directory-p (setq itm (strcat (substr dir 1 pos) "\\" itm)))
            itm
        (   dir   )
(defun LM:getfiles:sort ( lst )
    (apply 'append
        (mapcar 'LM:getfiles:sortlist
            (vl-sort
                (LM:getfiles:groupbyfunction lst
                    (lambda ( a b / x y )
                        (and
                            (setq x (vl-filename-extension a))
                            (setq y (vl-filename-extension b))
                            (= (strcase x) (strcase y))
                (function
                        (and
                            (setq x (vl-filename-extension (car a)))
                            (setq y (vl-filename-extension (car b)))
                            (< (strcase x) (strcase y))
(defun LM:getfiles:sortlist ( lst )
    (mapcar (function (lambda ( n ) (nth n lst)))
        (vl-sort-i (mapcar 'LM:getfiles:splitstring lst)
            (function
                    (while
                        (and
                            (setq x (car a))
                            (setq y (car b))
                            (= x y)
                        (setq a (cdr a)
                              b (cdr b)
                        (   (null x) b)
                        (   (null y) nil)
                        (   (and (numberp x) (numberp y)) (< x y))
                        (   (= "." x))
                        (   (numberp x))
                        (   (numberp y) nil)
                        (   (< x y))
(defun LM:getfiles:groupbyfunction ( lst fun / tmp1 tmp2 x1 )
    (if (setq x1 (car lst))
            (foreach x2 (cdr lst)
                (if (fun x1 x2)
                    (setq tmp1 (cons x2 tmp1))
                    (setq tmp2 (cons x2 tmp2))
            (cons (cons x1 (reverse tmp1)) (LM:getfiles:groupbyfunction (reverse tmp2) fun))
(defun LM:getfiles:splitstring ( str )
        (lambda ( l )
            (read
                (strcat "("
                    (vl-list->string
                        (apply 'append
                            (mapcar
                                (function
                                    (lambda ( a b c )
                                            (   (= 92 b)
                                                (list 32 34 92 b 34 32)
                                            (   (or (< 47 b 58)
                                                    (and (= 45 b) (< 47 c 58) (not (< 47 a 58)))
                                                    (and (= 46 b) (< 47 a 58) (< 47 c 58))
                                                (list b)
                                            (   (list 32 34 b 34 32))
                                (cons nil l) l (append (cdr l) '(( )))
        (vl-string->list (strcase str))
(defun LM:getfiles:browseforfolder ( msg dir flg / err fld pth shl slf )
    (setq err
        (vl-catch-all-apply
            (function
                (lambda ( / app hwd )
                    (if (setq app (vlax-get-acad-object)
                              shl (vla-getinterfaceobject app "shell.application")
                              hwd (vl-catch-all-apply 'vla-get-hwnd (list app))
                              fld (vlax-invoke-method shl 'browseforfolder (if (vl-catch-all-error-p hwd) 0 hwd) msg flg dir)
                        (setq slf (vlax-get-property fld 'self)
                              pth (LM:getfiles:fixdir (vlax-get-property slf 'path))
    (if slf (vlax-release-object slf))
    (if fld (vlax-release-object fld))
    (if shl (vlax-release-object shl))
    (if (vl-catch-all-error-p err)
        (prompt (vl-catch-all-error-message err))
        pth
The above is just a snippet of the file that I have attached.
It asks me a layer and I enter REVISION1 and then errors out.
Civil3D 2020
« Reply #24 on: July 10, 2014, 03:27:58 PM »
Sorry, I forgot to rename a few variables, try the attached.
MSTG007
« Reply #25 on: July 10, 2014, 03:42:05 PM »
dude... fully working over here! Its gonna be scary what things I can think about using this for... way cool. :mrgreen:
Civil3D 2020
« Reply #26 on: July 10, 2014, 04:53:28 PM »
Excellent to hear - I hope it saves you some time  :-)
HasanCAD
« Reply #27 on: July 12, 2014, 03:13:10 AM »
I belive that, this routine will be great if can read from Excel file (which has old and new layers) and names as "LAYTRANS-update"
MSTG007
« Reply #28 on: July 14, 2014, 07:15:04 AM »
Is it possible with this routine to do a batch xref. Lets say I have a project. All the files dwgs have the job number in the name. I then copy it to a new jopb number and rename those files. Can this possible help replace the paths with dwgs I have renamed rather than opening each drawing and browsing for each xref in all the drawings? :ugly:
Civil3D 2020
« Reply #29 on: July 14, 2014, 12:42:50 PM »
Certainly possible - but unfortunately more time & work than I can justify donating to the forum...
Yes, this should be possible -
You can simply pass a function to my LM:odbx function to modify the ActiveX Path property for each of your xrefs.
Here is a very rough example:
  3.         (LM:odbx
  4.            '(lambda ( doc / str )
  5.                 (vlax-for blk (vla-get-blocks doc)
  6.                     (if (and (= :vlax-true (vla-get-isxref blk))
  7.                              (wcmatch (setq str (vla-get-path blk)) "*oldjobnumber*")
  8.                         )
  9.                         (vla-put-path blk (vl-string-subst "newjobnumber" "oldjobnumber" str))
  10.                     )
  11.                 )
  12.             )
  13.             lst t
  14.         )
  15.     )
  16.     (princ)
  17. )
MSTG007
« Reply #30 on: July 14, 2014, 12:56:53 PM »
Lets have some fun here! I have tested the lsp. I can load up the files and then it saves the files but it seems that it does not re-path the xref to the new location. So for example original sheet name: 1234.1234.sheet1.dwg and 1234.1234.base.dwg, I copy to a new location of 2222.2222.sheet1.dwg with the base files, 2222.2222.base.dwg.
I then run the lsp. it would re-path the xref(s) to the new location. Do I need to specify the old job no and the new job no?
Civil3D 2020
« Reply #31 on: July 14, 2014, 01:06:32 PM »
Of course it doesn't - you did not specify any information about the format of the job number to be replaced, or what value it should be replaced with. So unless your xref paths coincidentally contained the string "oldjobnumber" as specified in the code, the program would not have done anything at all.
Yes, these are noted in the code.
MSTG007
« Reply #32 on: July 14, 2014, 01:15:06 PM »
lol. my bad. Let me try again! :ugly:
Civil3D 2020
MSTG007
« Reply #33 on: July 14, 2014, 01:23:48 PM »
Ok. I have tried it once again manually putting the job no in. Still no luck. It is revising the files to a degree I can see the date modified update.
[code(defun c:test ( / lst )
        (LM:odbx
                             (wcmatch (setq str (vla-get-path blk)) "*1234.1234*")
                        (vla-put-path blk (vl-string-subst "2222.2222" "1234.1234" str))
            lst t
Does \ could this be edited in the command line? oldjob newjob
Civil3D 2020
MSTG007
« Reply #34 on: July 16, 2014, 09:46:20 AM »
Ok. I have another one for you. Still with this bad boy! How about making it (purge all and purge registered apps, audit, fix errors if any and then save). I tell me head is on fire!
Civil3D 2020
