Author Topic: block created on layer 0, but "plot" turned off  (Read 1982 times)
GISDUDE
« on: July 02, 2014, 10:53:41 AM »
I have 58 blocks that were created on layer 0. I have since moved them to another layer, but, NOW WHEN I TRY TO TURN THEM ON THE NEW LAYER, they stay on.
Is there a way to change this? Really weird.
tedg
Re: block created on layer 0, but "plot" turned off
« Reply #1 on: July 02, 2014, 11:26:00 AM »
Have you checked the block geometry to see if the linework that was created on layer zero is ByLayer or ByBlock?
Also, the layer(s) you're moving them to, have you checked to make sure they're not set to NoPlot?
Windows 10 Pro 64bit, AutoCAD 2023, REVIT 2023
cadtag
« Reply #2 on: July 02, 2014, 12:25:10 PM »
Block definitions and block instances are two different beasts.
Verify the definition by using BEDIT & checking that the entities composing the block definition are all on layer 0, and all color/lineweights'linetypes are set to ByBlock.
Then check the block instances, and verify that the property of each instance is on the desired layer.
GISDUDE
« Reply #3 on: July 02, 2014, 03:14:26 PM »
How do you find "instances"? This block is the most unusual block. I have tried to explode and re-create a new block with a new title, but it STILL keeps the attributes on the ORIGINAL layer.
arrgh.....
cadtag
« Reply #4 on: July 02, 2014, 03:36:29 PM »
The inserted blocks are the instances --  there's only one block definition no matter how many times it's inserted, but there is an instance of the block for every insertion.  well, ignoring Annotative and Dynamic blocks that's true....
Attributes  are _attached_ to the block instance, but not really part of it.  that's why you can move/change properties of the attribute after the block is inserted.  The block definition holds the ATTDE (Attribute Definition) entities, but they are placed as Attributes when the block in inserted (instantiated)
clear as mud??
post your block, and someone can have a look at it and maybe explain what it's doing, or fix it so it does what you expect.
« Reply #5 on: July 02, 2014, 03:57:10 PM »
arrgh.....
sounds like the various pieces of geometry were created on specific layers and NOT on layer zero.
« Reply #6 on: July 02, 2014, 04:18:09 PM »
And use attsync after you redefine the block.
