Author Topic: P/Invoke acedGetAcadDwgView  (Read 3508 times)
AARYAN
« on: June 20, 2014, 07:48:33 AM »
Dear All,
I have a problem with DCL dialogs not removing themselves after they have
been closed until the lisp function is actually finished. I found a way in ARX but not in .NET.
Can anyone please guide me to invoke these lines in c#.net using P/Invoke method.
acedGetAcadDwgView()->InvalidateRect(NULL, TRUE);
acedGetAcadDwgView()->UpdateWindow();
& also
acedGetAcadFrame()->InvalidateRect(NULL, TRUE);
acedGetAcadFrame()->UpdateWindow();
Thanks in Advance.
AARYAN
Re: P/Invoke acedGetAcadDwgView
« Reply #1 on: June 25, 2014, 07:54:46 AM »
If any one at least point me How can it be done in .net it would be highly appreciable.
Thanks in Advance.
MexicanCustard
« Reply #2 on: June 25, 2014, 08:10:39 AM »
Code - C#: [Select]
  1. var ed = Application.DocumentManager.MDIActiveDocument.Editor;
  2. ed.UpdateScreen
  3.
Is that what you're looking for?
MexicanCustard
« Reply #3 on: June 25, 2014, 08:28:40 AM »
You can also try
System.Windows.Forms.Application.DoEvents()
If you need to interact with the Application window you can get its handle
[DllImport("user32.dll")]
static extern bool InvalidateRect(IntPtr hWnd, IntPtr lpRect, bool bErase);
static extern bool UpdateWindow(IntPtr hWnd);
Application.MainWindow.Handle
« Last Edit: June 25, 2014, 08:39:29 AM by MexicanCustard »
AARYAN
« Reply #4 on: June 25, 2014, 09:37:08 AM »
Thanks for your reply.
I have tried Editor.UpdateScreen but it does not cause any effect, then I tried Editor.Regen method with DoEvents() it removes the dialog box but does not show the process in the command line (e.g "\r" function) until the lisp get finishes.
I will try again with Handle and let you know.
Thanks for your time.
Regards
AARYAN
« Reply #5 on: June 27, 2014, 05:15:08 AM »
Dear  MexicanCustard,
I have tried the following code but with no success. Can you point me if I am missing anything as I am quite new in the .net world. I am using Windows7 x86.
using System;
using System.Runtime.InteropServices;
using System.Diagnostics;
using System.Windows.Forms;
namespace ClassLibrary1
    public class Class1
        [LispFunction("sRedraw")]
        public object CDRedraw(ResultBuffer LispArgs)
            Editor AcadEditor = AcadApp.DocumentManager.MdiActiveDocument.Editor;
            IntPtr hWnd = AcadApp.MainWindow.Handle;
            InvalidateRect(hWnd, IntPtr.Zero, true);
            UpdateWindow(hWnd);  // Tested upto here but not working.
            // added following code to test again. It does remove the dialog box
            // but the process in the commandline is not showing
            // e.g (princ (strcat "\rCreating Points" (itoa (1+ counter)) " of 2500"))
            AcadEditor.Regen();
            AcadEditor.UpdateScreen();
            System.Windows.Forms.Application.DoEvents();
            return null;
MexicanCustard
« Reply #6 on: June 27, 2014, 07:52:24 AM »
So you're trying to run a LISP routine while another LISP routine is active?  I'm not a LISP guy but I would think there is an easier solution going the modify the first LISP routine route.
Anyway, you might want to try creating a .NET command as a Transparent command so it can execute while the LISP routine is still active. Try this article
