Author Topic: Deck Rail Pickets Ideas Wanted  (Read 4498 times)
« on: June 18, 2014, 03:20:31 PM »
Trying to come up with a solution to a design problem.
The deck is new and over a parking area (carport). The 3/4" plywood is sealed with EDPM and 2x4 PT placed over that. (this is not my design but I was asked to solve the picket problem)
The current design has a drip edge of metal over a furring strip (red arrow) which is typical design.
The problem come when the Architect wants to use 2x2 pickets (shown in red) attached to the outside deck member and the beam (shown in yellow).
The already thin (1-1/2") picket is notched (red arrow) to only 3/4" thickness.
This is structural a weak design but he doesn't want to resort to post with pickets attached to a bottom rail.
I see no way around this problem.
I suppose we could use 2x3 pickets thus giving more material to notch.
Any other thoughts?
LE3
Re: Deck Rail Pickets Ideas Wanted
« Reply #1 on: June 18, 2014, 04:06:59 PM »
answer from an ex-architect... I lost all my knowledge on this.... :-(
Maybe place the verticals in front? and add some shims behind?
« Reply #2 on: June 18, 2014, 04:26:57 PM »
Thanks Luis.
That's a good one. Using furring strips (1x2 PT) would work in the bottom one but the top is only 1.5"x1.5"x.75" and hard to keep from splitting. Might need another material there.
Thanks for the idea.
LE3
« Reply #3 on: June 18, 2014, 04:35:40 PM »
Is interesting as to why the 2x4 flats were not aligned to the face of the plywood, instead of starting by leaving a gap.
I mean something like this:
« Last Edit: June 18, 2014, 04:44:45 PM by LE »
« Reply #4 on: June 18, 2014, 04:59:36 PM »
To allow for the Metal drip edge.
danallen
« Reply #5 on: June 18, 2014, 05:19:39 PM »
I'm an architect and would be very careful with that railing detail due to life safety. Decks are often not maintained and the wood can rot & weaken. Here is a JLC article on decks, doesn't specifically answer your question but includes guidelines.
https://drive.google.com/file/d/0Bz-dFCmwk0cGanl4dlhKdmRrREE/edit?usp=sharing
« Reply #6 on: June 18, 2014, 09:22:11 PM »
Good article. I tend to be more cautious as i get older. 8)
I recommended The furred out method or 2x3 pickets to maintain the 1-1/2" working thickness.
Also using (3) Simpson SDWS22500DB fasteners.
Daniel J. Ellis
« Reply #7 on: June 19, 2014, 03:15:21 AM »
Could you notch the decking and have a gap in the drip strip for each picket?
That would allow the pickets to fix directly to the beam.
dJE
dJE
« Reply #8 on: June 19, 2014, 07:19:38 AM »
Yeah, its a bad design looking for a resolution, and unfortunately CAB is the one that needs to find it!
I have never liked the idea of wood elements for railing in an exposed setting. Considering the inherent weakness of 2x2 pickets fastened in that manner after a few years of weathering, I don't believe it would be safe after the wood starts to dry out and check.
TimSpangler
  • CAD Naked!!
« Reply #9 on: June 19, 2014, 07:30:07 AM »
CAB,
How are the newel's attached?  In this situation we would attach the balusters the a horizontal member attached to the newels, not the rimboard of the deck.
ACA 2015 - Windows 7 Pro
« Reply #10 on: June 19, 2014, 08:06:09 AM »
dJE
I would love to do that but trying to seal all those would be a messy looking nightmare.
« Reply #11 on: June 19, 2014, 08:10:47 AM »
CAB,
You want newel's too! No that would spoil to look.  He he he....
The Architect  wants balusters only. That is the structural dilemma.
To complicate it he wants the deck water tight with a drip edge.
GDF
« Reply #12 on: June 19, 2014, 12:15:07 PM »
I vote for 2x3 pickets
« Reply #13 on: June 19, 2014, 01:52:34 PM »
I vote for a new architect!
Strucmad
« Reply #14 on: June 19, 2014, 07:26:34 PM »
Interesting design, so no post and rail, pickets only.
Assuming this is fairly high off the ground I would be interested in what
the EOR has to say about that connection.
Over here most post and rail balustrades fail to comply with the code required loads.
Agree with Keith... vote for new architect
*edit
Strike those concerns, bending stress appears fine.. very suprised
« Last Edit: June 19, 2014, 07:59:49 PM by PS_Port »
