Author Topic: Unique xy point list but ignore z  (Read 7435 times)
XXL66
« on: June 18, 2014, 10:32:54 AM »
hi,
i have a 3D point list and would like to remove the duplicates (with a fuzz for xy only) but it should ignore the z values doing this, however the return list should still have the z values included for the point.
thus points (1.0 2.0 2.1) and (1.0 2.01 3.0) or considered equal (xy with 0.01 fuzz) and the first should be returned in the list (1.0 2.0 2.1).
any ideas ? ty !
XXL66
Re: Unique xy point list but ignore z
« Reply #1 on: June 18, 2014, 10:54:55 AM »
with help from LM ! ty LM !
but i'm wondering is there a inverse cdr function ? every item but the last ?  (reverse (cdr (reverse x))) ?
(defun LM:UniqueFuzzXY ( l f / x r )
    (while l
        (setq x (car l)
      x_ (list (car x) (cadr x))
              l (vl-remove-if (function (lambda ( y ) (equal x_ (list (car y) (cadr y)) f))) (cdr l))
              r (cons x r)
    (reverse r)
ymg
« Reply #2 on: June 18, 2014, 11:16:47 AM »
(defun butLast (l) (reverse (cdr (reverse l))))
We call it butlast and it is exactly as you proposed.
ymg
LE3
« Reply #3 on: June 18, 2014, 11:22:04 AM »
^ yes, many of us (old ones or x-lispers) remember this place: http://autocad.xarch.at/news/faq/autolisp.html
Good times - indeed!.
ymg
« Reply #4 on: June 18, 2014, 03:39:12 PM »
You must be my age, Luis.
ymg
LE3
« Reply #5 on: June 18, 2014, 04:10:24 PM »
ymg
21? (hehe.... aha)... Have fun! (btw good code stuff you have posted lately)
« Reply #6 on: June 18, 2014, 07:06:48 PM »
roy_043
  • BricsCAD 18
« Reply #7 on: June 19, 2014, 03:55:41 AM »
Not very important but...
The variable x_ is not localized in LM:UniqueFuzzXY.
XXL66
« Reply #8 on: June 19, 2014, 04:18:46 AM »
yes, but that's my fault, not LM's !
BTW LM. I use another function from you that i use in a function to create a gradient color map on a tin (hsltorgb). The doslib version works fine, but yours gives me strange results...see attached picture.
Something seems to go wrong with the conversion.
XXL66
« Reply #9 on: June 19, 2014, 04:25:50 AM »
Very important (from your site):
... Arkey (a Dutch CAD program) and BricsCAD (After chocolates, the next best Belgian export product).
 :wink:
roy_043
  • BricsCAD 18
« Reply #10 on: June 19, 2014, 08:14:02 AM »
 :wink:
I agree with you that BricsCAD is a very good product. But let's not forget the excellent Belgian beers... :laugh:
XXL66
« Reply #11 on: June 19, 2014, 08:42:43 AM »
Yes, belgian beers, tell me about it, but you dutch made a major leap with La Trappe (quadrupel) ...
« Reply #12 on: June 19, 2014, 02:18:42 PM »
Note that the DOSLib function is dos_hlstorgb, whereas my function is LM:hsl->rgb... this may be causing some problems if the saturation & luminance arguments are supplied in the wrong order.
Here is an updated version of my code to make it more concise:
  1. ;; HSL -> RGB  -  Lee Mac
  2. ;; Args: [int] 0<=h<=360, 0<=s<=100, 0<=l<=100
  3.
  4. (defun LM:HSL->RGB ( h s l / u v )
  5.     (setq h (/ h 360.0)
  6.           s (/ s 100.0)
  7.           l (/ l 100.0)
  8.     )
  9.     (mapcar '(lambda ( x ) (fix (+ 0.5 (* 255 x))))
  10.         (cond
  11.             (   (zerop s) (list l l l))
  12.             (   (zerop l)'(0 0 0))
  13.             (   (setq v (if (< l 0.5) (* l (1+ s)) (- (+ l s) (* l s)))
  14.                       u (-  (* 2.0 l) v)
  15.                 )
  16.                 (mapcar
  17.                    '(lambda ( h )
  18.                         (setq h (rem (1+ h) 1))
  19.                         (cond
  20.                             (   (< (* 6.0 h) 1.0) (+ u (* 6.0 h (- v u))))
  21.                             (   (< (* 2.0 h) 1.0) v)
  22.                             (   (< (* 3.0 h) 2.0) (+ u (* 6.0 (- (/ 2.0 3.0) h) (- v u))))
  23.                             (   u   )
  24.                         )
  25.                     )
  26.                     (list (+ h (/ 1.0 3.0)) h (- h (/ 1.0 3.0)))
  27.                 )
  28.             )
  29.         )
  30.     )
  31. )
XXL66
« Reply #13 on: June 20, 2014, 03:28:38 AM »
Oops, really need to make an appointment with the ophthalmologist !
thx !
« Reply #14 on: June 21, 2014, 08:39:05 AM »
No worries  :-)
Do the two functions now produce identical results?
