Author Topic: Arg! I hate when I'm in VB ...  (Read 4523 times)
« on: April 11, 2005, 04:52:08 PM »
... and I type "defun" !!!
:evil:
Carry on ...
Jeff_M
  • C3D user & customizer
« Reply #1 on: April 11, 2005, 11:34:57 PM »
Heh, I can't count how many times I've typed "setq"......
« Reply #2 on: April 11, 2005, 11:36:31 PM »
It's more maddening than it sounds, I do it all the time !!! Grrr.
« Reply #3 on: April 11, 2005, 11:43:01 PM »
... typing the curley brackets in VLisp is a pain too ..
or the other way around .. parenthesis in c# is more likely.
And sometimes not as noticable.
I use old age as an excuse, how do you guys justify it to yourselves :)
« Reply #4 on: April 11, 2005, 11:46:13 PM »
IIRC I'm 47 in a couple months, so I'm blaimin' it on age.
« Reply #5 on: April 12, 2005, 08:46:34 AM »
heh!? Ive written almost an entire lisp procedure in the VBA editor. *lol*
ML
« Reply #6 on: April 12, 2005, 05:30:26 PM »
See, it is The VBA Gods telling you that VBA Rules!   :)
Jeff_M
« Reply #7 on: April 12, 2005, 06:37:38 PM »
Are you sure it's not the other way around? It seems to me that if we all keep placing lisp code into the VBAIDE that would mean it really wants to be done in lisp....... :D
And MP, I can't let you get away with the age thing.....since I've got you beat by half a year, or so, and I was just going to use the old dogs/new tricks excuse... :D
« Reply #8 on: April 12, 2005, 10:21:44 PM »
That 1/2 year has you movin' a little slower I guess.
