Need explanation is: I was doing the calculation of 3D pipeline, the original data is the axis of space I two lines,
first, obtains closest points between two axes by GetClosestPointTo method, result is P0, P1,
then, create two Solid3d, then get all Face 3D object's surface obtained by Brep,
finally, get the surface's closest point to P0, P1 by ClosestPointTo method, result is Pa, Pb,
then the distance pa to pb is the nearest distance between two Solid3d.
