Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Spline created with selection of 3d points/nodes
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Spline created with selection of 3d points/nodes (Read 1396 times)
luisternou
Newt
on:
June 12, 2014, 07:33:10 PM »
Hello!
As said I am looking for a lisp that creates/ draws a fit curved spline after selecting 3d points/nodes. The points are the Z coordinates on a train rail.
The plan is to connect the two created splines (left and right rail) into a smooth surface.
Thanks in advance!
Regards,
Luis
Logged
ymg
Guest
Re: Spline created with selection of 3d points/nodes
Reply #1 on:
June 12, 2014, 08:00:59 PM »
How is one supposed to derive the order of the points ?
If it is along a coordinate axis, it can be done easily,
otherwise there is no guaranties as to the order of
the points returned by ssget
ymg
Logged
luisternou
Newt
Reply #2 on:
June 19, 2014, 01:19:31 PM »
I found this lisp. This did the job for me. If you place the points yourself in a specific order, it creates the (s)pline in that same order. If you have imported xyz data it takes the nearest second point etc. after window selection.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
