Author Topic: A question about the grips  (Read 1949 times)
2e4lite
« on: June 04, 2014, 09:30:19 PM »
   Why are the marked grips of objects that are only some circles ,lines and arcs(not  block) to following  far from the objects in highlight?
« Last Edit: June 07, 2014, 09:21:09 PM by 2e4lite »
Crank
Re: A question about the grips
« Reply #1 on: June 09, 2014, 04:55:54 AM »
The marked grips belong to the arc. If I remeber it well, the distance to the arc has to do with the zoom factor.
In a more recent version of Autocad they've removed the triangle grips and the square grips are now also used for these options. The system variable GRIPMULTIFUNCTIONAL controls how this works.
2e4lite
« Reply #2 on: June 09, 2014, 09:51:57 PM »
  Your reply is to the point.I have to use a smaller window before apply sssetfirst to highlight in cad09.Thank you very much.
