Author Topic: Corrupted hatch in dynamic blocks  (Read 1362 times)
NICK_VNV
« on: June 04, 2014, 08:46:19 AM »
When I insert dynamic blocks with associated hatch inside some of them have corrupted hatch (and it goes normal if I change any grip which affect boundary of hatch). If drawing contains many such blocks it becomes hard to fix them all manually, so i wrote a lisp to update all their subents and regen the drawing. Also I noticed double regen is required to see the result. Here is my version
    (defun c:block_hatch_fix ()
    (princ "\nStart..")
    (vlax-for blk (vla-get-Blocks (vla-get-ActiveDocument (vlax-get-Acad-Object)))
        (vlax-for obj blk
                (vlax-invoke-method obj 'Update)
    (command "_.regenall")
    (princ "\nComplete")
Maybe somebody find this usefull or can improve the code.
kpblc
Re: Corrupted hatch in dynamic blocks
« Reply #1 on: June 05, 2014, 01:13:11 AM »
Maybe problem appears because you hatches are associative.
Sorry for my English.
