Author Topic: On Drawing Close (save or No Save)  (Read 5184 times)
GumbyCAD
Re: On Drawing Close (save or No Save)
« Reply #15 on: June 05, 2014, 01:35:24 AM »
Well at first glance, WOW.
I totally understand were you coming from as I am a structural guy too.  (But Draftsman turned Programmer - try hard)
I understand why you destroy the Event
But a lot of what you have I don't understand, mostly because I dont understand dictionaries.
Thanks for Sharing.  I will study it some more , need to do some reading on dictionaries first.
Stephan
WILL HATCH
« Reply #16 on: June 05, 2014, 01:48:16 AM »
This is the reason for writing the code.  I'm an electrical engineer, this extra job was just a pain and wanted it to go away lol
Dictionaries are pretty simple, you store and access objects by a key.  It's very fast, which is why I use it in the overridden methods to access data.
GumbyCAD
« Reply #17 on: June 05, 2014, 01:50:53 AM »
Whats the difference between using List(of ObjectType) or Dictionary?  (VB Code sorry)
Is one better than the other?
They seam to do the same job.
Stephan
WILL HATCH
« Reply #18 on: June 05, 2014, 02:06:04 AM »
very similar, the dictionary provides indexing.
I use a dictionary<objectId, CustomDataObject> meaning the customdataobject (value) is accessed by the objectid (key)
Each key value pair is quickly accessible by the key
This is important in the example as I am dealing with per object data and it allows me to access the correct data.
In your case, this could be applicable where you create a dictionary and upon drawing creation you construct some data about the drawing, then when the save event fires you save a copy of that data, and when the tobedestroyed event fires you delete the data from your dictionary
