Author Topic: Multiple View Port Plans in one layout help  (Read 2091 times)
MSTG007
« on: June 02, 2014, 09:27:46 AM »
I have a question for you guys. I found a drawing that has multiple plans in one layout tab. However when you go to model space... Everything is on and its hard to decipher what layers are on view ports etc.
Does anyone have an idea how to organize a clutter of drawing?
thanks
Civil3D 2020
Rob...
Re: Multiple View Port Plans in one layout help
« Reply #1 on: June 02, 2014, 09:29:59 AM »
I usually work through the viewport, make sure it is locked, though. You can also use maximize viewport.
CAD Tech
MSTG007
« Reply #2 on: June 02, 2014, 09:31:29 AM »
Is there a way to export the current layers state out and restore it in model space or something?
Civil3D 2020
Rob...
« Reply #3 on: June 02, 2014, 09:33:19 AM »
Not that I know of.
Is there a problem with working through the viewport?
CAD Tech
MSTG007
« Reply #4 on: June 02, 2014, 09:34:07 AM »
I don't think so. Its another person working on it. I can see.
Civil3D 2020
ChrisCarlson
« Reply #5 on: June 09, 2014, 03:37:19 PM »
If you have different viewports to filter layers, best to work in that viewport.
You can also create layer groups and mass on/off within model space however this can negatively affect the viewports.
« Reply #6 on: June 09, 2014, 03:53:16 PM »
from your description the clutter has been organized
into views with various layers froze in those views
as others have noted
Make use of the views by Locking them, and utilizing Maximize viewport command lower right on your screen
a squarish thing with and arrow on it
This lets one work on the entire model 'as if' in model space while maintaining the viewport layer state
