Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
.NET
Topic:
How do i get selectionset with a specific name?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: How do i get selectionset with a specific name? (Read 2292 times)
Rusel
Guest
on:
June 01, 2014, 09:21:30 PM »
Hello,
I am new to .net and used vba for years.
In vba I was creating a selectionset with a name in a sub and able to get it somewhere else with its name and use it like:
Dim Sset As SelectionSet = doc.SelectionSets.Item("myselectionset")
How can I do this in .net?
Thanks,
Logged
Gasty
Newt
Re: How do i get selectionset with a specific name?
Reply #1 on:
June 01, 2014, 11:30:08 PM »
Why do you need a name?, the managed API selection set class hasn't a name property for an instance of a selection set. You have a variable which contains the selection set, that's it.
Gaston Nunez
Logged
WILL HATCH
Bull Frog
Reply #2 on:
June 02, 2014, 01:27:09 AM »
You'd need to create an object to hold all the selection sets, if you don't need this defined outside of the current document scope then just add a dictionary to your command class. If you need it shared across documents then declare it static.
Code - C#:
[Select]
public
Commands
Dictionary
string
, SelectionSet
SelectionSets
new
Dictionary
string
, SelectionSet
public
void
DoStuff
SelectionSet ss
ed
GetSelection
SelectionSets
add
"DoStuffSet"
,ss
public
void
DoThings
SelectionSet ss
SelectionSets
"DoStuffSet"
Logged
Rusel
Guest
Reply #3 on:
June 02, 2014, 10:03:54 PM »
Thanks,
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
.NET
Topic:
