added a functionality wich I call "VisibilitySpace". check it Out...
Any feedback is welcome...
greets reltro
I use visibility all the time, so having it in the menu is great. the only feedback I would give is: When you switch the visibility to "invisible" the "Hide" button should really say "UnHide".
Otherwise, great addition!
Hey Tim,
First, thanks for the great feedback.
My thinking was: "hide" an object from current Visibilty-Space
> hide from invisible-Space makes it visible
> other way around, u know
But, u gave me a great hint.
At the moment the displayed vectors are pre-calculated (except for the last command) and "hard-coded" (the compiler did this
) in the menu.
It may should be possible to make the displayed text, and graphic sensitive to the current conditions.........
In the case of the Title-Text (the vectors shown in green, below) it wouldn't be so hard (the function is allready part of the complied Menu), but it would be also neceassary to give a possibility to control wich one is displayed on wich condition.
hmmmm.... I have to think about it, but it would be nice I guess.
At the moment I'm trying to reduce the File-size of the compiled RadialMenu. Draw-Modify was about 3MB, now it has allready 2,5MB
This addition would increase the file-size again.
I want to keep the file-size small, at the other hand, I think that the most of the vectors should be precalculated, so the Menu can run smoothly, without multiple calculations of the same.
If u have a suggestion what this condition-senstive-display should deliver and how it can be implemented in the most generic way, any ideas are very welcome =)
My first idea is to add a new "tag" in the raw-file, a lambda-expr wtithout any input, wich returns an Integer, wich is interpreted like (nth [returned integer] [combination of graphic and title-text])...
greets retlro
