Author Topic: wcmatch help?  (Read 2693 times)
cadman6735
wcmatch help?
« on: May 29, 2014, 10:53:02 AM »
I can not figure out why this will not work?  "too few arguments"   :realmad: I am arguing with it and it still won't work...   :ugly:
  (vlax-for eachLayer acLayers
    (if (eq (wcmatch (strcase (vla-get-name eachLayer)) "*A-ANNO-SEAL"))
      (vla-put-freeze eachLayer :vlax-true)
reltro
Re: wcmatch help?
« Reply #1 on: May 29, 2014, 10:56:38 AM »
Hey
try this, can't test it...
    (if (wcmatch (strcase (vla-get-name eachLayer)) "*A-ANNO-SEAL")
removed the (eq
reltro
cadman6735
Re: wcmatch help?
« Reply #2 on: May 29, 2014, 10:59:24 AM »
Seriously???
Thank you very much....
cmwade77
Re: wcmatch help?
« Reply #3 on: May 29, 2014, 04:42:10 PM »
Please note that in AutoCAD 2015, you cannot use a pattern like "*A-ANNO-SEAL" as it is treated the same as "*", which I learned the hard way yesterday. The * must be in the middle or at the end of the string only.
Re: wcmatch help?
« Reply #4 on: May 29, 2014, 04:58:39 PM »
I cannot reproduce this behavio(u)r  :?
cmwade77
Re: wcmatch help?
« Reply #5 on: May 29, 2014, 07:39:10 PM »
How strange, it's what was happening to me yesterday.
