Author Topic: How can i get the current Language Name of AutoCAD (only managed C++ code)  (Read 9082 times)
melomayo
I am still looking for a comfortable solution.
Before I load any AutoCAD Linetype, must firstly checked of current AutoCAD version and current Language Pack.
How can I do this? any ideas ?  :-o  :?
Code - C++: [Select]
  1. static void print_LocalInfo ( void )
  2. {
  3.         //
  4.         // Get RoamableRootFolder :
  5.         // "C:\Users\[loginname]\AppData\Roaming\Autodesk\AutoCAD 2015\R20.0\enu\"
  6.         //
  7.
  8.         const ACHAR* pRoamableRootFolder;
  9.
  10.         acdbHostApplicationServices()->getRoamableRootFolder( pRoamableRootFolder );
  11.
  12.         // [b]How can i get the Language Name with unmanaged C++ ?[/b]
  13.         // ISO 639x Value : Language Name
  14.
  15.         CString ENU = "ENU";
  16.         CString DEU = "DEU";
  17.
  18.         // [b]How can i get the Culture Name with unmanaged C++ ?[/b]
  19.         //
  20.         // "en-US" // English - United States
  21.         // "de-DE" // German  - Germany
  22.
  23.         CString rf = pRoamableRootFolder;
  24.         CString ts = rf.Mid(rf.GetLength() - ENU.GetLength() - 1, ENU.GetLength());
  25.
  26.         ::acutPrintf(_T("\nYour Language is: %s"), (ENU == ts.MakeUpper()) ? L"Englisch" : L"Deutsch");
  27. }
  28.
Reference : see also National Language Support - (NLS) API Reference Information for Windows 7
exmachina
Maybe this can be done using AcRxDynamicLinker::ProductLcid.
It's Alive!
  • Retired
  • AKA Daniel
there is a locale system variable too (getvar "locale")
Retired
melomayo
Hi Jar,
thanks for your help, with method
  1. acrxDynamicLinker->ProductLcid()
I get following result:
AutoCAD English: ProductLcid = 1033
AutoCAD Englisch with German Language Pack: ProductLcid = 1031
Kean Walmsley has written an .NET example:
Determining AutoCADís language using .NET:  http://through-the-interface.typepad.com/through_the_interface/2014/03/determining-autocads-language-using-net.html
Code - C#: [Select]
  1. using System.Globalization;
  2. using Autodesk.AutoCAD.ApplicationServices;
  3. using Autodesk.AutoCAD.Runtime;
  4.
  5. namespace LanguageInfo
  6. {
  7.   public class Commands
  8.   {
  9.     [CommandMethod("LANG")]
  10.     public static void WhichLanguage( )
  11.     {
  12.       var cult = new CultureInfo(SystemObjects.DynamicLinker.ProductLcid);
  13.       Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage( "\nLanguage of your AutoCAD product is {0}.", cult.EnglishName );
  14.     }
  15.   }
  16. }
  17.
My question is how can I use similar class CultureInfo in C++/ARX  (not CLR) ?
How can i use the function ::GetLocaleInfo for determine the LocalId?
melomayo
Hi nullptr,
both version give me the same result
AutoCAD English: (getvar "LOCALE") = "DEU"
AutoCAD Englisch with German Language Pack: (getvar "LOCALE") =  "DEU"
thanks for your help  :-)
melomayo
I have following code form Google,
maybe is that usefull
The Original Source code is from J. Michael McGarrah ( mcgarrah@mcgarware.com )
  1.         static void get_LocalInfo ( void )
  2.         {
  3.                 // Retrieves the active input locale identifier.
  4.                 HKL hKl = ::GetKeyboardLayout( 0 );
  5.
  6.                 // LOWORD of the returned value contains the language identifier.
  7.                 LANGID langID = LOWORD((DWORD) hKl );
  8.
  9.                 // Retirieve the information about the locale
  10.                 LCID lcID = MAKELCID( langID, SORT_DEFAULT );
  11.
  12.                 const int kLen = 7;
  13.                 const int sLen = 100;
  14.
  15.                 TCHAR chPage         [ kLen     ];
  16.                 TCHAR szCurrency     [ kLen     ];
  17.                 TCHAR szVal          [ MAX_PATH ];
  18.                 TCHAR szFormatString [ sLen     ];
  19.
  20.                 // Get currently ised code page.
  21.                 ::GetLocaleInfo(lcID, LOCALE_IDEFAULTANSICODEPAGE, chPage, kLen);
  22.                 int m_iCodePage = atoi((const char *)chPage);
  23.
  24.                 // Get default OEM code page.
  25.                 ::GetLocaleInfo(lcID, LOCALE_IDEFAULTCODEPAGE, chPage, kLen);
  26.                 int m_iOEMCodePage = atoi((const char *) chPage);
  27.
  28.                 // Get country name in english.
  29.                 ::GetLocaleInfo(lcID, LOCALE_SENGCOUNTRY, szVal, MAX_PATH);
  30.                 CString m_strCountry = szVal;
  31.
  32.                 // Get country code -- not sure if this works
  33.                 ::GetLocaleInfo(lcID, LOCALE_ICOUNTRY, chPage, kLen);
  34.                 int m_iCountryCode = atoi((const char *)chPage);
  35.
  36.                 // Get language name.
  37.                 ::GetLocaleInfo(lcID, LOCALE_SENGLANGUAGE, szVal, MAX_PATH);
  38.                 CString m_strLanguage = szVal;
  39.
  40.                  // Get TimeFormat String
  41.                 ::GetLocaleInfo(lcID, LOCALE_STIMEFORMAT, szFormatString, sLen);
  42.                 CString m_strTimeFormat = szFormatString;
  43.
  44.                 // Get Date Format String
  45.                 ::GetLocaleInfo(lcID, LOCALE_SLONGDATE, szFormatString, sLen);
  46.                 CString m_strDateFormat = szFormatString;
  47.
  48.                 // Get the string used for local currency.
  49.                 ::GetLocaleInfo(lcID, LOCALE_SCURRENCY, szCurrency, kLen);
  50.                 CString m_strCurrency = szCurrency;
  51.
  52.
  53.                 // Get time format specifier i.e. 12 hour (AM/PM) or 24 hour format
  54.                 // is used to indicate time.
  55.                 ::GetLocaleInfo(lcID, LOCALE_ITIME, szVal, 3);
  56.
  57.                 CString m_strTimeFormatSpecifier = ( atoi ( (const char *) szVal ) == 0 ) ? "AM / PM 12-hour format" : "24-hour format";
  58.
  59.                 // Get calendar type
  60.                 ::GetLocaleInfo( lcID, LOCALE_ICALENDARTYPE, szVal, 3 );
  61.
  62.                 CString m_strCalendarType;
  63.
  64.                 switch ( atoi( (const char *) szVal ) )
  65.                 {
  66.                         case 1:
  67.                                 m_strCalendarType = ("Gregorian - Localized");
  68.                                 break;
  69.                         case 2:
  70.                                 m_strCalendarType = ("Gregorian - English strings always");
  71.                                 break;
  72.                         case 3:
  73.                                 m_strCalendarType = ("Year of the Emperor - Japan");
  74.                                 break;
  75.                         case 4:
  76.                                 m_strCalendarType = ("Year of Taiwan");
  77.                                 break;
  78.                         case 5:
  79.                                 m_strCalendarType = ("Tangun Era - Korea");
  80.                                 break;
  81.                         case 6:
  82.                                 m_strCalendarType = ("Hijri - Arabic lunar");
  83.                                 break;
  84.                         case 7:
  85.                                 m_strCalendarType = ("Thai");
  86.                                 break;
  87.                         case 8:
  88.                                 m_strCalendarType = ("Hebrew - Lunar");
  89.                                 break;
  90.                         case 9:
  91.                                 m_strCalendarType = ("Gregorian Middle East French");
  92.                                 break;
  93.                         case 10:
  94.                                 m_strCalendarType = ("Gregorian Arabic");
  95.                                 break;
  96.                         case 11:
  97.                                 m_strCalendarType = ("Gregorian Transliterated English");
  98.                                 break;
  99.                         case 12:
  100.                                 m_strCalendarType = ("Gregorian Transliterated French");
  101.                                 break;
  102.                         default:
  103.                                 m_strCalendarType = ("Unknown");
  104.                 }
  105.
  106.                 // Get the ID of the language identifier.
  107.                 LANGID langId = ::GetSystemDefaultLangID();
  108.
  109.                 DWORD dwSize, dwError, dwReturnedSize;
  110.
  111.                 ACHAR szLanguage[ MAX_PATH ];
  112.
  113.                 // Get the string for the language identifier.
  114.                 dwSize = MAX_PATH;
  115.                 dwReturnedSize = VerLanguageName(langId, szLanguage, dwSize);
  116.
  117.                 CString m_strLocaleLocalLanguage;
  118.
  119.                 if ( dwReturnedSize <= dwSize )
  120.                 {
  121.                         m_strLocaleLocalLanguage = szLanguage;
  122.                 }
  123.
  124.                 // Get time zone information.
  125.                 TIME_ZONE_INFORMATION info;
  126.                 TCHAR szTimezone[31];
  127.
  128.                 dwError = ::GetTimeZoneInformation(&info);
  129.
  130.                 CString m_strLocaleTimeZone;
  131.
  132.                 if ( TIME_ZONE_ID_INVALID != dwError )
  133.                 {
  134.                         wsprintf( szTimezone, L"%s", info.StandardName );
  135.
  136.                         m_strLocaleTimeZone = szTimezone;
  137.                 }
  138.
  139.                  ::acutPrintf(_T("\n------------------   ") );
  140.                  ::acutPrintf(_T("\nLOCALE INFORMATION   ") );
  141.                  ::acutPrintf(_T("\n------------------   ") );
  142.                  ::acutPrintf(_T("\nCodePage:      %d    "), m_iCodePage              );
  143.                  ::acutPrintf(_T("\nOEMCodePage:   %d    "), m_iOEMCodePage           );
  144.                  ::acutPrintf(_T("\nLanguage:      %s    "), m_strLanguage            );
  145.                  ::acutPrintf(_T("\nDateFormat:    %s    "), m_strDateFormat          );
  146.                  ::acutPrintf(_T("\nCountry:       %s    "), m_strCountry             );
  147.                  ::acutPrintf(_T("\nCountryCode:   %d    "), m_iCountryCode           );
  148.                  ::acutPrintf(_T("\nTimeFormat:    %s    "), m_strTimeFormat          );
  149.                  ::acutPrintf(_T("\nCurrency:      %s    "), m_strCurrency            );
  150.                  ::acutPrintf(_T("\nTimeFrmSpec.:  %s    "), m_strTimeFormatSpecifier );
  151.                  ::acutPrintf(_T("\nCalendarType:  %s    "), m_strCalendarType        );
  152.                  ::acutPrintf(_T("\nLocalLanguage: %s    "), m_strLocaleLocalLanguage );
  153.                  ::acutPrintf(_T("\nTimeZone:      %s    "), m_strLocaleTimeZone      );
  154.                  ::acutPrintf(_T("\n"));
  155.
  156.         }
  157.
