Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
.NET
Topic:
Slice a region
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Slice a region (Read 2960 times)
Andrey Bushman
Swamp Rat
Slice a region
on:
May 26, 2014, 03:53:29 AM »
* AutoCAD 2009 SP3 Enu x86/x64
It is necessary to slice a region object as a grid (dx, dy). The result is the new collection of regions.
My current decision: I create the Solid3d based on the target region and slice it as a grid. So I got many Solid3d objects. Then I explode each of the Solid3d and remove the excess regions.
But my decision is slow (in my opinion). Can I get the same result without the Solid3d creating?
Thank you.
Last Edit: May 26, 2014, 05:25:15 AM by Andrey Bushman
Logged
SEANT
Bull Frog
WWW
Re: Slice a region
Reply #1 on:
May 26, 2014, 07:45:02 AM »
Perhaps you could systematically construct a region based on the (dx, dy), create a copy of the original target region, then Boolean Intersect the two. Repeat as necessary.
Logged
Sean Tessier
AutoCAD 2016 Mechanical
Andrey Bushman
Swamp Rat
Re: Slice a region
Reply #2 on:
May 27, 2014, 02:09:32 PM »
Quote from: SEANT on May 26, 2014, 07:45:02 AM
I use it now, thank you.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
.NET
Topic:
Slice a region
