Author Topic: Is it superfluous?  (Read 3182 times)
2e4lite
Is it superfluous?
« on: May 22, 2014, 11:40:57 PM »
(setq lname (strcase (cdr (assoc 2 (tblsearch "layer" lay_chname)) ) ))
In any case, can remove the strcase above (is it superfluous)? why?
hanhphuc
Re: Is it superfluous?
« Reply #1 on: May 23, 2014, 01:53:03 AM »
hi.. If the layer name is in numeric string like "0" "123", case unchanged.
so strcase can be ignored.
( apply 'equal "hp" "happy" "hạnh phúc" "ハッピー" "幸福" "행복" ) ; error: too many arguments
roy_043
  • BricsCAD 18
« Reply #2 on: May 23, 2014, 04:16:45 AM »
What if tblsearch returns nil?
pBe
« Reply #3 on: May 23, 2014, 04:58:08 AM »
I was about to post that same question
Assuming lay_chname value is the result of a user typing the layername
(if (tblsearch "layer" (setq lname (strcase lay_chname)))
        lname
dgorsman
« Reply #4 on: May 23, 2014, 10:16:29 AM »
Depends on what's being done with the value afterwards.  If its being tested for equality against another string, then it could be important to do it or not, if case sensitivity is an issue.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
chlh_jd
« Reply #5 on: May 26, 2014, 03:27:00 PM »
Table name always  ignore case when you use search or change entities's table name or make entities with it , like you use tblsearch / entmod / entmake .
Why we used strcase , just like dgorsman said ,  Easy to use these function which no ignore case , like  wcmatch / = / member etc.  .
roy_043
  • BricsCAD 18
« Reply #6 on: May 27, 2014, 07:21:25 AM »
@ 2e4lite: ?
2e4lite
« Reply #7 on: May 27, 2014, 09:19:10 PM »
I got it.Thanks you all.
