I write the plugins for AutoCAD 2015. But it is unpossible to write the unit tests for AutoCAD plugins as the MS Visual Studio tests. Because they must work in the acad.exe process.
For solving its problem I use Gallio. It has own plugin for testing of AutoCAD plugins.
So, when I press the F5 key in Visual Studio, it runs the Gallio.Echo.exe with the necessary arguments. Then Gallio.Echo.exe launches the acad.exe and loads my tests into this process. So my IDE are connected to the Gallio.Echo.exe, but my code are working in the acad.exe.
![](http://i.stack.imgur.com/rj2Xz.png)
All works fine, but I have one desire: I want in my code the working break points in the DEBUG mode. Now they are ignored.
Can I solve this problem?
P.S. I use a remote debugging, if it is important.
