Author Topic: Error from Linker : LNK1120: unresolved externals  (Read 3701 times)
melomayo
« on: May 19, 2014, 05:53:28 AM »
Why do I get this error from Linker?
Error 1 error LNK2019:
unresolved external symbol "public: static void __cdecl CKMLIBLayer::FreezeAll(void)" (?FreezeAll@CKMLIBLayer@@SAXXZ)
referenced in function "public: static void __cdecl CKMLIB2015App::KM_MyGroupTest(void)" (?KM_MyGroupTest@CKMLIB2015App@@SAXXZ) J:\...\acrxEntryPoint.obj
Error 2 error LNK1120:
1 unresolved externals   J:\...\x64\Debug\KM_KMLIB2015.arx
thank you in advance for your help  :wink:
File: acrxEntryPointc.pp
Code - C++: [Select]
  1. #include "StdAfx.h"
  2. #include "resource.h"
  3. #include "dbmain.h"
  4.
  5. #include "Layer.h"
  6.
  7. //-----------------------------------------------------------------------------
  8.
  9. #define szRDS _RXST("")
  10.
  11. //-----------------------------------------------------------------------------
  12.
  13. class CKMLIB2015App : public AcRxArxApp {
  14.
  15.         public:
  16.
  17.         CKMLIB2015App () : AcRxArxApp ()
  18.         {
  19.         }
  20.
  21.         virtual AcRx::AppRetCode On_kInitAppMsg   ( void *pkt )
  22.         {
  23.                 return AcRxArxApp::On_kInitAppMsg ( pkt ) ;
  24.         }
  25.         virtual AcRx::AppRetCode On_kUnloadAppMsg ( void *pkt )
  26.         {
  27.                 return AcRxArxApp::On_kUnloadAppMsg ( pkt ) ;
  28.         }
  29.         virtual void RegisterServerComponents     ( )
  30.         {
  31.
  32.         }
  33.
  34.         static void KM_MyGroupTest       ( )
  35.         {
  36.                 ::acutPrintf( _T("\nTest called: " ));
  37.
  38.                 CKMLIBLayer::FreezeAll();
  39.         }
  40. } ;
  41.
  42. IMPLEMENT_ARX_ENTRYPOINT  ( CKMLIB2015App )
  43. ACED_ARXCOMMAND_ENTRY_AUTO( CKMLIB2015App, KM_MyGroup, Test, Test, ACRX_CMD_MODAL, NULL )
  44.
  45.
File: Layer.cpp
  4.
  5. class CKMLIBLayer
  6. {
  7.         public:
  8.
  9.         CKMLIBLayer ( void )
  10.         {
  11.
  12.         }
  13.
  14.       ~CKMLIBLayer ( void )
  15.         {
  16.
  17.         }
  18.
  19.
  20.         static void FreezeAll ( )
  21.         {
  22.                 AcDbLayerTable       *pTable  = NULL;
  23.                 AcDbLayerTableRecord *pRecord = NULL;
  24.
  25.                 Acad::ErrorStatus     acEs;
  26.
  27.                 // open the layertable in the current drawing
  28.
  29.                 if( (acEs = acdbHostApplicationServices()->workingDatabase()->getLayerTable( pTable, AcDb::kForRead )) != Acad::eOk )
  30.                 {
  31.                         acutPrintf( _T("\nCouldn't get the layer table: %s" ), acadErrorStatusText( acEs ));
  32.
  33.                         return;
  34.                 }
  35.
  36.                 AcDbObjectId currentId = acdbHostApplicationServices()->workingDatabase()->clayer();
  37.
  38.                 AcDbObjectId recordId;
  39.
  40.                 AcDbLayerTableIterator *pIter;
  41.
  42.                 for( pTable->newIterator( pIter ); !pIter->done(); pIter->step() )
  43.                 {
  44.                         acEs = pIter->getRecordId(recordId);
  45.
  46.                         if( acEs != Acad::eOk )
  47.                         {
  48.                                 acutPrintf( _T("Cannot get layer %s"),acadErrorStatusText( acEs ));
  49.                                 continue;
  50.                         }
  51.
  52.                         if( recordId == currentId )
  53.                                 continue;
  54.
  55.                         AcDbObject *pObj = NULL;
  56.
  57.                         acEs    = acdbOpenAcDbObject( pObj, recordId, AcDb::kForWrite );
  58.                         pRecord = AcDbLayerTableRecord::cast( pObj );
  59.
  60.                         if( acEs != Acad::eOk || pRecord == NULL)
  61.                         {
  62.                                 acutPrintf(_T("Cannot open layer %s"),acadErrorStatusText(acEs));
  63.
  64.                                 if( pObj != NULL )
  65.                                         pObj->close();
  66.
  67.                                 continue;
  68.                         }
  69.
  70.                         acEs = pRecord->setIsFrozen( Adesk::kTrue );
  71.
  72.                         pRecord->close();
  73.
  74.                         if( acEs != Acad::eOk )
  75.                         {
  76.                                 acutPrintf(_T("Cannot set layer to be frozen %s"),acadErrorStatusText(acEs));
  77.                         }
  78.
  79.                         pRecord = NULL;
  80.                 }
  81.
  82.                 delete pIter;
  83.
  84.                 pTable->close();
  85.         }
  86. };
  87.
File: Layer.h
  1. #pragma once
  2.
  3. class CKMLIBLayer
  4. {
  5.         public:
  6.
  7.         CKMLIBLayer ( void );
  8.    ~CKMLIBLayer ( void );
  9.
  10.         static void FreezeAll ();
  11. };
  12.
  13.
melomayo
Re: Error from Linker : LNK1120: unresolved externals
« Reply #1 on: May 19, 2014, 08:57:56 AM »
Problem was solved
  4. #include "Layer.h"
  5.
  6. //class CKMLIBLayer
  7. //{
  8. //      public:
  9.
  10.         CKMLIBLayer::CKMLIBLayer()
  11.         {
  12.
  13.         }
  14.
  15.         CKMLIBLayer::~CKMLIBLayer (  )
  16.         {
  17.
  18.         }
  19.
  20.
  21.         void CKMLIBLayer::FreezeAll ( )
  22.         {
  23.                 AcDbLayerTable       *pTable  = NULL;
  24.                 AcDbLayerTableRecord *pRecord = NULL;
  25.
  26.                 Acad::ErrorStatus     acEs;
  27.
  28.                 // open the layertable in the current drawing
  29.
  30.                 if( (acEs = acdbHostApplicationServices()->workingDatabase()->getLayerTable( pTable, AcDb::kForRead )) != Acad::eOk )
  31.                 {
  32.                         acutPrintf( _T("\nCouldn't get the layer table: %s" ), acadErrorStatusText( acEs ));
  33.
  34.                         return;
  35.                 }
  36.
  37.                 AcDbObjectId currentId = acdbHostApplicationServices()->workingDatabase()->clayer();
  38.
  39.                 AcDbObjectId recordId;
  40.
  41.                 AcDbLayerTableIterator *pIter;
  42.
  43.                 for( pTable->newIterator( pIter ); !pIter->done(); pIter->step() )
  44.                 {
  45.                         acEs = pIter->getRecordId(recordId);
  46.
  47.                         if( acEs != Acad::eOk )
  48.                         {
  49.                                 acutPrintf( _T("Cannot get layer %s"),acadErrorStatusText( acEs ));
  50.                                 continue;
  51.                         }
  52.
  53.                         if( recordId == currentId )
  54.                                 continue;
  55.
  56.                         AcDbObject *pObj = NULL;
  57.
  58.                         acEs    = acdbOpenAcDbObject( pObj, recordId, AcDb::kForWrite );
  59.                         pRecord = AcDbLayerTableRecord::cast( pObj );
  60.
  61.                         if( acEs != Acad::eOk || pRecord == NULL)
  62.                         {
  63.                                 acutPrintf(_T("Cannot open layer %s"),acadErrorStatusText(acEs));
  64.
  65.                                 if( pObj != NULL )
  66.                                         pObj->close();
  67.
  68.                                 continue;
  69.                         }
  70.
  71.                         acEs = pRecord->setIsFrozen( Adesk::kTrue );
  72.
  73.                         pRecord->close();
  74.
  75.                         if( acEs != Acad::eOk )
  76.                         {
  77.                                 acutPrintf(_T("Cannot set layer to be frozen %s"),acadErrorStatusText(acEs));
  78.                         }
  79.
  80.                         pRecord = NULL;
  81.                 }
  82.
  83.                 delete pIter;
  84.
  85.                 pTable->close();
  86.         }
  87.
  88. //};
  89.
