Author Topic: PacMan game v1.2 completed. More refined version of v1.1  (Read 14084 times)
liuhaixin88
Re: PacMan game v1.2 completed. More refined version of v1.1
« Reply #15 on: May 19, 2014, 10:25:13 PM »
error happened (when appload)
   PacMan [v1.2].LSP for AutoCAD v2002 loaded ...
                         Type Ppz to start game
   Create Custom level>> WS=define gameplay viewsize,
                         DP=draw pathline, DW=draw wall,
                         SD=draw smalldots, BD=entmod to big dot
                         MapGame=write game level to file
   Misc. function     >> HL=toggle Highlight on/off,
                         EF=toggle image frame on/off
                         GM=toggle grid mode on/off
                         AN=create animation path (creating Logo animation etc)
; error: bad argument type: stringp nil
Command:
Try setting the PacMan folder to AutoCad path
I Create a folder in C: disk ,rename "PacMan" , add this floder to support file search path.
appload "PacMan [v1.2].LSP" An error occurred “error: bad argument type: stringp nil”
What steps are still missing?
RAIN CODE
« Reply #16 on: May 20, 2014, 03:49:50 AM »
Tried it in Visual Lisp Editor:
error: PPF Internal: unexpected ctoken type
hmmm...honestly I really dont know what that means. Does anyone know  ?
Are you running it on Autocad 2002 ?
liuhaixin88
« Reply #17 on: May 20, 2014, 03:56:41 AM »
This routine only run on acd2002 ?
RAIN CODE
« Reply #18 on: May 20, 2014, 04:02:12 AM »
To Liuhaixin88,
Try this...
upzip the file pacman (v1.2).zip to a temp folder.
Then move the whole Pacman folder to drv C.
Hope this will help.
RAIN CODE
« Reply #19 on: May 20, 2014, 04:07:19 AM »
(was searching for the modify button for
 the first page but cant find it)
This lisp only works on AutoCad v2002.
Sorry..
« Last Edit: May 20, 2014, 04:17:10 AM by RAIN CODE »
liuhaixin88
« Reply #20 on: May 20, 2014, 04:22:54 AM »
Sorry..
You are  OP ? so please Login using  “ RainCode v1.2 ” ,
divtiply
« Reply #21 on: May 20, 2014, 04:45:29 AM »
Raincode:
Your VBA code is incompatible with x64.
Consider to remove VBA dependency.
Here is the snippet:
(defun play-sound (url)
  (vlax-put-property (cond (*windowsmediaplayer*)
                           ((setq *windowsmediaplayer* (vlax-create-object "WMPlayer.OCX"))))
                     'url url))
RAIN CODE
« Reply #22 on: May 22, 2014, 05:32:01 AM »
Raincode:
                     'url url))
I am not familiar with VBA code. What does the above code do ?
But this thing only run on Acad ver 2002.
RAIN CODE
« Reply #23 on: May 22, 2014, 05:39:49 AM »
Sorry..
oh ya I was using another ID.
Created another one becos I tried to log in
at the cybercafe but forgotten about the password. Hate to travel back home to get password.
RainCode v1.2
« Reply #24 on: May 25, 2014, 02:54:39 AM »
Video posted but still in processing for alomst 45 mins already... ??? Is this normal
Anyway, the Video Links below are for,  "How to.... for PacMan v1.2 game"
How to create a PacMan custom level
(using AutoCad)
http://www.youtube.com/watch?v=m96x8KNlXj4&feature=youtu.be
How to create a Jpeg background
(required PhotoShop CS2)
http://www.youtube.com/watch?v=bvbTbmel_Go&feature=youtu.be
How to use Automate Batch editing to create background effect in bulk
http://www.youtube.com/watch?v=UMc7tCoetcw&feature=youtu.be
divtiply
« Reply #25 on: May 25, 2014, 01:05:21 PM »
Raincode:
                     'url url))
The exaple provided is not VBA code, this is VisualLisp. It plays sound files (wma, mp3 & others supported by Windows Media Player). Should work with AutoCAD 2000 & above (x32/x64), BricsCAD (x32/x64), ZWCAD, GstarCAD, progeCAD and probably CorelCAD (heck, what a zoo!)
try (your path to file may vary):
(play-sound "c:\\windows\\media\\tada.wav")
Your sound playing code depends on VBA DVB files. VBA DVB code is not supported in BricsCAD x64. AutoCAD 2009 & above supports VBA with additional module instalation only. AutoCAD x64 VBA needs different code (it's about function pointers).
To make your code more portable I recommend to rewrite sound routines using only VisualLisp. You may use my snippet for it.
With a little modification it should run under all above mentioned CADs.
« Last Edit: May 25, 2014, 01:27:15 PM by divtiply »
RAIN CODE
« Reply #26 on: May 27, 2014, 11:44:15 AM »
At first I try to run this lisp on Autocad ver
2008 but the screen turned white. I dont
know why that happened then I write it for
Autocad ver2002.
The sound code wasnt written by me. I
found it on a forum.
But if I change the sound code to make it
run on higher ver it still cannot run becoz
You ahould try it on higher ver then you
will know what I mean.
cmwade77
« Reply #27 on: May 27, 2014, 06:54:52 PM »
I only have AutoCAD 2014 and 2015, so I can't play with this, looks cool though.
RAIN CODE
« Reply #28 on: May 27, 2014, 11:48:07 PM »
I want it to run on higher ver too so other
ppl with higher can play it but I just
dont know how to solve the white screen
problem.
cmwade77
« Reply #29 on: May 28, 2014, 12:57:59 PM »
problem.
I would like to even get that far, but I get the same issue as in this post:
http://www.theswamp.org/index.php?topic=47087.msg521312#msg521312
Perhaps if I can get that error resolved, then I can look at the white screen error.
