Author Topic: Linker Warning 4099  (Read 5209 times)
melomayo
Linker Warning 4099
« on: May 15, 2014, 06:09:47 AM »
How can I turn off this Linker warning ?
i have Visual Studio 2012 SP4, Windows 7 - 64 bit, AutoCAD 2015.
The Option /ignore:4099 is in command line added.
Thank You from Germany  :wink:
"rxapi.lib(libinit.obj) : warning LNK4099: PDB 'rxapi_cl.pdb' was not found with 'rxapi.lib(libinit.obj)' or at 'C:\Users\...\rxapi_cl.pdb'; linking object as if no debug info"
"warning LNK4099: PDB 'rxapi_cl.pdb' was not found with 'rxapi.lib(libinit.obj)' or at 'C:\Users\ ... \rxapi_cl.pdb'; linking object as if no debug info"
MickD
  • (x-in)->[process]->(y-out)
Re: Linker Warning 4099
« Reply #1 on: May 15, 2014, 06:40:09 AM »
I don't think you can, it's appearing as you are linking a release build lib in with your debug app build and you don't have the debug info for the referenced lib.
I wouldn't worry, it's only a warning (unless you have set 'treat warnings as errors' to on).
"The E in Javascript stands for 'easy'." Florin Pop tweet
melomayo
« Reply #2 on: May 15, 2014, 06:49:41 AM »
Hi MickD,
thank you.
MickD
« Reply #3 on: May 15, 2014, 05:50:47 PM »
No worries, not much help though :)
It's nice to have a 'clean' build at all times but don't let a few warnings (that you know about and understand) stop you from producing your app, you can waste a lot of time unnecessarily just to get a clean build, it isn't worth it IMO.
Mick.
