Author Topic: Track Active Drawing  (Read 4538 times)
UWPMVG
  • Mosquito
Re: Track Active Drawing
« Reply #15 on: May 20, 2014, 03:51:38 PM »
I will keep looking for a solution for this problem. If any of you comes up with something, let me know. :-)
UWPMVG
  • Mosquito
« Reply #16 on: May 26, 2014, 01:30:34 PM »
I found the solution with help from Kean Walmsley.
The following code works:
AddHandler AcApp.DocumentManager.DocumentActivated, AddressOf Me.DocumentManager_DocumentActivated
Private Sub DocumentManager_DocumentActivated(ByVal sender As Object, ByVal e As DocumentCollectionEventArgs)
        If Application.DocumentManager.MdiActiveDocument IsNot Nothing Then
            MsgBox("Active drawing has changed!")
        End If
End Sub
