Author Topic: selection of blocks  (Read 4961 times)
TAIKI
selection of blocks
« on: May 10, 2014, 03:56:05 PM »
Hello
First I’m sorry for my English, I’m French.
Just i want to pick a polyline and the result is a selection of all blocks who have the insertion point on this polyline.
After all bloc selected move on the layer of the polyline.
And do it on all polyline on the same layer.
ymg
Re: selection of blocks
« Reply #1 on: May 10, 2014, 07:48:59 PM »
TAIKI,
Use your polyline as a fence for a selection and filter for block only.
(defun c:test (/ fence)
   (setq fence (listpol (car (entsel "\nSelectionnez le polyligne: "))))
   (sssetfirst nil (ssget "_F" fence '((0 . "INSERT"))))
;;; listpol   by Gille Chanteau                                               ;
;;; Returns the vertices list of any type of polyline (WCS coordinates)       ;
;;; Argument        ;
;;; en, a polyline (ename or vla-object)                                      ;
(defun listpol (en / i p l)
  (setq i (if (vlax-curve-IsClosed en)
       (vlax-curve-getEndParam en)
     (+ (vlax-curve-getEndParam en) 1)
  (while (setq p (vlax-curve-getPointAtParam en (setq i (1- i))))
      (setq l (cons (trans p 0 1 ) l))
ymg
TAIKI
« Reply #2 on: May 11, 2014, 02:10:07 AM »
Thank you
It’s a good start, just it is possible that filtered more to not take attributes on blocks but just the insertion point or all object.
And the most important do it on all polyline on the same layer, so when lisp prompt to select a polyline the code take all polyline in the same layer that the polyline you pick. To displace all blocks on all polyline on the same layers.
Thanks for your time.
snownut2
  • Bricscad 22 Ultimate
« Reply #3 on: May 11, 2014, 07:41:44 AM »
Another drive-thru lisp order.
mailmaverick
« Reply #4 on: May 11, 2014, 01:03:24 PM »
Assuming your polyline is 2D, you can use (vla-getboundingbox ....) method to find out the bounding box of the polyline.
Then you can do (ssget "_CP" (list Pt1 Pt2 Pt3 Pt4) (list (cons 0 "INSERT"))) .... of all block entities within this bounding box.
where Pt1, Pt2, Pt3 and Pt4 are the vertices of this bounding box. Note to do  (vla-zoomwindow (vlax-get-acad-object) (vlax-3d-point pt1) (vlax-3d-point pt3)) before you do above ssget because it is important that the vertices of the polygon within which you want to get entities must be zoomed in on screen. Here Pt1 and Pt3 are (minx, miny) and (maxx, maxy) coordinates of the bounding box.
Then you can iterate through all the objects to find their insertion point and check whether the point lies on the polyline or not using (vlax-curve-getDistAtPoint..... method.
ymg
« Reply #5 on: May 11, 2014, 03:06:05 PM »
TAIKI,
Assuming you assign the Selection Set to variable ss.
Now iterate through it, the insertion point will be given by:
    (setq pl (cons (cdr (assoc 10 (entget (ssname ss (setq i (1- i)))))) pl))
ymg
TAIKI
« Reply #6 on: May 11, 2014, 03:44:49 PM »
thanks a lot
Sorry i'm starting with autolisp.
YMG your first code worked fine, but can you explain me how you create a variable ss to intergrate the code who give the insertion point for filtered.
if it take too time i would know if it possible to intergate a code like that:
  1. [/  (cond
  2.     (js
  3.       (sssetfirst nil js)
  4.       (initget "Existant Nouveau _Existent New")
  5.       (if (eq (getkword "\nTraiter jeu de sélection [Existant/Nouveau] <Existant>: ") "New")
  6.         (progn (sssetfirst nil nil) (setq js (ssadd) js (ssget)))
  7.       )
  8.     )
  9.     (T (setq js (ssget)))
  10.   )
  11. ]
  12.
ymg
« Reply #7 on: May 11, 2014, 04:04:59 PM »
   (setq ss (ssget "_F" fence '((0 . "INSERT"))))
;;; Argument        ;
(setq ss (ssget "_F" fence '((0 . "INSERT")))) you are assigning your selection set to variable ss
TAIKI
« Reply #8 on: May 11, 2014, 04:27:05 PM »
okay
it work fine but not easy to use. For me if your first code can do the job on many polyline at once it would be fantastique.
thank you for your help.
ymg
« Reply #9 on: May 11, 2014, 04:44:11 PM »
TAIKI,
All the ingredients are there.
Now you need to create a selection set of all the polylines.
Iterates the solution for as many polyline as you have.
Basically the same thing as when we go through the block.
Wrap your head around it, try to come up with the solution.
Post your code and If you need help, will do.
ymg
Bhull1985
« Reply #10 on: May 12, 2014, 02:21:04 PM »
Hint:
'((0 . "LINE,LWPOLYLINE"))))
TAIKI
« Reply #11 on: May 12, 2014, 04:13:25 PM »
i think i have a bug:
Code - C#: [Select]
  1. defun c:test (/ js fence ss i pl)
  2. (or
  3.     (setq js (ssget "_I"))
  4.     (setq js (ssget "_P"))
  5.   )
  6.   (cond
  7.     (js
  8.       (sssetfirst nil js)
  9.       (initget "Existant Nouveau _Existent New")
  10.       (if (eq (getkword "\nTraiter jeu de sélection [Existant/Nouveau] <Existant>: ") "New")
  11.         (progn (sssetfirst nil nil) (setq js (ssadd) js (ssget)))
  12.       )
  13.     )
  14.  (cond
  15.     (js
  16. (setq fence (listpol(car js)))
  17.          setq ss (ssget "_F" fence '((0 . "INSERT"))))
  18.   (repeat (setq i (sslength ss))
  19.       (setq pl (cons (cdr (assoc 10 (entget (ssname ss (setq i (1- i)))))) pl))
  20.    )
  21.    )
  22. )
  23.
  24. ;;; listpol   by Gille Chanteau                                               ;
  25. ;;; Returns the vertices list of any type of polyline (WCS coordinates)       ;
  26. ;;;        ;
  27. ;;; Argument        ;
  28. ;;; en, a polyline (ename or vla-object)                                      ;
  29.
  30. (defun listpol (en / i p l)
  31.   (setq i (if (vlax-curve-IsClosed en)
  32.              (vlax-curve-getEndParam en)
  33.              (+ (vlax-curve-getEndParam en) 1)
  34.           )
  35.   )
  36.  (while (setq p (vlax-curve-getPointAtParam en (setq i (1- i))))
  37.      (setq l (cons (trans p 0 1 ) l))
  38.  )
  39. )
  40.
  41.
  42.
  43.
« Last Edit: May 16, 2014, 02:52:36 PM by TAIKI »
ymg
« Reply #12 on: May 12, 2014, 04:38:50 PM »
TAIKI,
You got more than one bug.
First and foremost subfunction listpol is expecting
an ename as argument.  You are supplying (car js).
Variable js is a selection set, you have to iterate through it,
or transform it in a list of ename.
ymg
TAIKI
« Reply #13 on: May 13, 2014, 03:16:51 PM »
it's better but idon't understand;
  1. (defun c:test (/ js fence ss i pl)
  2.     (setq js (ssget "_I"))
  3.     (setq js (ssget "_P"))
  4.   )
  5.   (cond
  6.     (js
  7.       (sssetfirst nil js)
  8.       (initget "Existant Nouveau _Existent New")
  9.       (if (eq (getkword "\nTraiter jeu de sélection [Existant/Nouveau] <Existant>: ") "New")
  10.         (progn (sssetfirst nil nil) (setq js (ssadd) js (ssget)))
  11.       )
  12.     )
  13.     (T (setq js (ssget)))
  14.   )
  15.   (cond
  16.     (js
  17. (setq fence (listpol(ssname js (setq n (1- n)))))
  18.          setq ss (ssget "_F" fence '((0 . "INSERT"))))
  19.    (repeat (setq i (sslength ss))
  20.        (setq pl (cons (cdr (assoc 10 (entget (ssname ss (setq i (1- i)))))) pl))
  21.     )
  22.    )
  23. )
  24.
  25. ;;; listpol   by Gille Chanteau                                               ;
  26. ;;; Returns the vertices list of any type of polyline (WCS coordinates)       ;
  27. ;;;        ;
  28. ;;; Argument        ;
  29. ;;; en, a polyline (ename or vla-object)                                      ;
  30.
  31. (defun listpol (en / i p l)
  34.           )
  35.   )
  36.       (setq l (cons (trans p 0 1 ) l))
  37.   )
  38. )
« Last Edit: May 16, 2014, 02:59:41 PM by TAIKI »
ymg
« Reply #14 on: May 13, 2014, 08:30:23 PM »
TAIKI,
I believe you have problem making the difference between a selection set and an ename.
A Selection Set is a special list of ename, you access it like so:
(repeat (setq i (sslength js))
   (setq ename (ssname js  (setq i (1- i)))
         fence (listpol ename)
   (repeat (setq n (sslength ss))
       (setq pl (cons (cdr (assoc 10 (entget (ssname ss (setq n (1- n)))))) pl))
Try to plug this in your routine.
ymg
TAIKI
« Reply #15 on: May 14, 2014, 04:22:10 PM »
Hello
Just for information of my progression for the moment insuffisant numbers of argument on setq ename.
  1. (defun c:test (/ ename fence ss i pl)
  2.   (or
  5.   )
  6.   (cond
  7.     (js
  10.      (if
  11.        (eq (getkword
  12.              "\nTraiter jeu de sélection [Existant/Nouveau] <Existant>: "
  13.            )
  14.            "New"
  15.        )
  16.         (progn (sssetfirst nil nil)
  17.                (setq js (ssadd)
  18.                      js (ssget)
  19.                )
  20.         )
  21.      )
  22.     )
  23.     (T (setq js (ssget)))
  24.     (cond
  25.      (js
  26.        (repeat (setq i (sslength js))
  27.          (setq ename (ssname js (setq i (1- i)))
  28.                fence (listpol ename)
  29.                ss (ssget "_F" fence '((0 . "INSERT")))
  30.                (repeat (setq i (sslength ss))
  31.                  (setq pl
  32.                         (cons
  33.                           (cdr (assoc 10
  34.                                       (entget (ssname ss (setq i (1- i))))
  35.                                )
  36.                           )
  37.                           pl
  38.                         )
  39.                  )
  40.                )
  41.          )
  42.        )
  43.
  44. ;;; listpol   by Gille Chanteau                                               ;
  45. ;;; Returns the vertices list of any type of polyline (WCS coordinates)       ;
  46. ;;;        ;
  47. ;;; Argument        ;
  48. ;;; en, a polyline (ename or vla-object)                                      ;
  49.
  50.        (defun listpol (en / i p l)
  51.          (setq i (if (vlax-curve-IsClosed en)
  52.                    (vlax-curve-getEndParam en)
  53.                    (+ (vlax-curve-getEndParam en) 1)
  54.                  )
  55.          )
  56.          (while
  57.            (setq p (vlax-curve-getPointAtParam en (setq i (1- i))))
  58.             (setq l (cons (trans p 0 1) l))
  59.          )
  60.        )
  61.      )
  62.     )
  63.   )
  64. )
« Last Edit: May 16, 2014, 03:00:31 PM by TAIKI »
ymg
« Reply #16 on: May 14, 2014, 05:01:01 PM »
TAIKI,
The two repeat loops are nested.
You cannot use the same variable as index.
    (repeat (setq j (sslength ss))
       (setq pl (cons (cdr (assoc 10 (entget (ssname ss (setq j (1- j)))))) pl))
Do use code tags around your code when posting in the Forum.
To do so Highlight the code you pasted in the reply window
and press on the # button.
ymg
TAIKI
« Reply #17 on: May 15, 2014, 04:46:57 PM »
hello
OK i have correct some parenthesis probleme the lisp charge succesfuly but now i have this error:
no function definition: LISTPOL
  1. (defun c:test (/ ename fence listpol ss j pl)
  2.   (or
  5.   )
  6.   (cond
  7.     (js
  11.         (progn
  12.           (sssetfirst nil nil)
  13.           (setq
  14.             js (ssadd)
  15.             js (ssget)
  16.           )
  17.         )
  18.       )
  19.     )
  20.     (T
  21.       (setq js (ssget))
  22.     )
  23.   )
  24.   (cond
  25.     (js
  27.         (setq
  28.           ename (ssname js (setq i (1- i)))
  29.           fence (listpol ename)
  30.           ss (ssget "_F" fence '((0 . "INSERT")))
  31.         )
  32.       )
  33.       (repeat (setq j (sslength ss))
  34.         (setq pl
  35.           (cons
  36.             (cdr (assoc 10 (entget (ssname ss (setq j (1- j))))))
  37.             pl
  38.           )
  39.         )
  40.       )
  41.     )
  42.   )
  43. ;;; listpol by Gille Chanteau ;
  44. ;;; Returns the vertices list of any type of polyline (WCS coordinates) ;
  45. ;;; ;
  46. ;;; Argument ;
  47. ;;; en, a polyline (ename or vla-object) ;
  48.   (defun listpol (en / i p l)
  49.     (setq i
  50.       (if (vlax-curve-IsClosed en)
  51.         (vlax-curve-getEndParam en)
  52.         (+ (vlax-curve-getEndParam en) 1)
  53.       )
  54.     )
  55.     (while
  56.       (setq p (vlax-curve-getPointAtParam en (setq i (1- i))))
  57.       (setq l (cons (trans p 0 1) l))
  58.     )
  59.   )
  60. )
snownut2
« Reply #18 on: May 15, 2014, 04:52:26 PM »
It appears that the function "listpol" is within the "c:test" function.
Place it prior to the rest of the code in "c:test" function, then it should work.
« Reply #19 on: May 15, 2014, 04:53:37 PM »
It's because you have it localized (defun c:test (/ ename fence listpol ss j pl) and it is defined after your routine runs. Put it at the top of your code.
*too slow
TAIKI
« Reply #20 on: May 15, 2014, 05:09:50 PM »
it's not resolved listpl on the top or not i have the same problem.
thank you.
ymg
« Reply #21 on: May 15, 2014, 05:41:01 PM »
TAIKI,
I told you the repeat Loop are nested.
and they must be nested.
In your last code this is not what you are doing.
JS est une selection de polyligne.
Pour chaque polyligne de la selection JS tu crees
une selection de blocs dans SS, c'est la premiere boucle repeat
Pour chacun des blocs dans SS tu obtiens la coordonnee
du point d'insertion que tu accumules dans la liste PL,
c'est la seconde boucle repeat
Tu traites le prochain polyligne.
Tous les polylignes sont traites PL contiens tous
les points d'insertion.
Autre point, je crois que ton "cond" ne vas pas.
Pour debuter oublie la preselection ne fais qu'une
selection de polyligne avec (SSGET)
Une fois que tu maitrises, tu pourras rajouter la preselection.
Je vois que tu as trouve comment faire pour inserer le code dans le forum.
C'est bien, maintenant tu devrais modifier tes anciens "post" pour les rajouter.
(defun c:test (/ ename fence listpol ss  i j pl)
   ;;; Argument                                                               ;
  ;---------Corps du Programme------------------------------------------------;
    (prompt "\nSelectionnez les Polylignes a traiter: ")
    (if (setq js (ssget '((0 . "*POLYLINE"))))
           ); Fin Seconde Boucle repeat
       ); Fin Premiere Boucle repeat
ymg
« Last Edit: May 15, 2014, 06:08:19 PM by ymg »
TAIKI
« Reply #22 on: May 17, 2014, 07:18:07 PM »
hello
Thanks a lot ymg, i think i have do some improvement but i have an error bad argument numberp: nil.
  1. (defun c:test (/ listpol ename fence ss j k pl all)
  2. ;;; listpol by Gille Chanteau ;
  3. ;;; Returns the vertices list of any type of polyline (WCS coordinates) ;
  4. ;;; ;
  5. ;;; Argument ;
  6. ;;; en, a polyline (ename or vla-object) ;
  7.   (defun listpol (en / i p l)
  8.     (setq i
  9.       (if (vlax-curve-IsClosed en)
  10.         (vlax-curve-getEndParam en)
  11.         (+ (vlax-curve-getEndParam en) 1)
  12.       )
  13.     )
  14.     (while
  15.       (setq p (vlax-curve-getPointAtParam en (setq i (1- i))))
  16.       (setq l (cons (trans p 0 1) l))
  17.     )
  18.   )
  19.   ;---------Corps du Programme------------------------------------------------;
  20.  (princ "\nSélectionnez les polylignes: ")
  21.  (or
  22.     (setq js (ssget "_I"))
  23.     (setq js (ssget "_P"))
  24.   );or
  25.   (cond
  26.     (js
  27.       (sssetfirst nil js)
  28.       (initget "Existant Nouveau _Existent New")
  29.       (if (eq (getkword "\nTraiter jeu de sélection [Existant/Nouveau] <Existant>: ") "New")
  30.         (progn
  31.           (sssetfirst nil nil)
  32.           (setq
  33.             js (ssadd)
  34.             js (ssget)
  35.           )
  36.         )
  37.       );js
  38.     );cond
  39.     (T
  40.       (setq js (ssget))
  41.     );t
  42.   );or
  43. ;---------------------fin de preselection------------------------;
  44.  (setq all (ssadd))
  45.   (cond      ;1
  46.     (js
  47.       (repeat (setq i (sslength js))   ;1
  48.         (setq
  49.           ename (ssname js (setq i (1- i)))
  50.           fence (listpol ename)
  51.           ss (ssget "_F" fence '((0 . "INSERT")))
  52.         );setq
  53. ;----------------------------------------------------------------;
  54.         (cond     ;2
  55.           (ss
  56.         (repeat (setq i (sslength ss))    ;2
  57.           (setq pl (cons (cdr (assoc 10 (entget (ssname ss (setq j (1- j))))))pl))
  58. ;----------------------------------------------------------------;
  59.          (cond   ;3
  60.            (pl
  61.              (repeat (setq k (sslength pl))   ;3
  62.                (ssadd (ssname pl (setq k (1- k))) all)
  63.               );repeat3
  64.             );pl
  65. ;-----------------------------------------------------------------;
  66.                );cond3
  67.               );repeat2
  68.              );ss
  69.             );cond2
  70.         );repeat1
  71.    (sssetfirst nil all)
  72.           );js
  73.     );cond1
  74.  (prin1)
  75. );defun
i've write some note but i don't know if it was a probleme
ymg
« Reply #23 on: May 17, 2014, 08:16:49 PM »
TAIKI,
Did you try last code I posted ?
Problem is you want to play with pre-selection
forget it for the moment.
You don't use the cruise control while learning to drive.
Another reason not to use pre-selection you would need
to check every item to filter out anything that is not a
polyline.
Another question why do you use cond when an if will do ?
ymg
« Last Edit: May 17, 2014, 08:54:21 PM by ymg »
TAIKI
« Reply #24 on: May 22, 2014, 03:46:58 PM »
ymg
sorry for the time i'm worked on night.
ok i forget pre-selection but if i've undertand correcly  pl return list of insertion point of all bloc on ss but for select just bloc who have insertion point on polylin, i'll compare whith js.
My question is what function do that
ymg
« Reply #25 on: May 22, 2014, 05:07:52 PM »
TAIKI,
pl is the list of Insertion Points for every blocks that is
we accumulate in pl every blocks picked up by each
polyline that are in js.
So the code segment that does the accumulating
is the second repeat loop.
Now the above repeat loop is being repeated for each polyline in js
That why we say that the second loop is nested inside the first one.
ymg
« Last Edit: May 22, 2014, 05:13:09 PM by ymg »
TAIKI
« Reply #26 on: May 26, 2014, 04:20:43 PM »
hello
Ymg, I want to thanks you for your time, but i think i'm not ready for this lisp. For the moment I learn with easiest code and when I'll be better I'll do this code.
So thank you and see you soon for my future lisp.
Taiki
