Author Topic: increase number of attribute block along a polyline  (Read 8256 times)
pedroantonio
« on: May 10, 2014, 03:08:42 AM »
Hi,Is it possible to increase number of attribute block along a polyline allways in clockwise direction. Look the attach test2.dwg
reltro
Re: increase number of attribute block along a polyline
« Reply #1 on: May 10, 2014, 07:34:15 AM »
Hey...
its possible for sure...
Start with PseudoCode:
1. Select Polyline
2. Pick the Point
3. Get the Vertices of the Polyline
4. Sort them, so that the vertices nearest to the Point in 2. is the first.
5. reverse or not the list from step 4. to be clockwise
6. insert BlockReference on each vertex
7. change Attribute value
An approach...
(defun From1to4 ( / vertices entselOut PickPoint dist StartIndex)
   (setq   entselOut   (entsel "Pick a polyline near to the startpoint")
         PickPoint   (cadr entselOut)
         vertices   (mapcar
                     'cdr
                     (vl-remove-if-not
                        '(lambda (a / )
                           (= (car a) 10)
                        (entget (car entselOut))
         StartIndex   (vl-position
                     (apply
                        'min
                        (setq dist
                           (mapcar
                              '(lambda (a / )
                                 (distance PickPoint a)
                              vertices
                     dist
   (repeat StartIndex (setq vertices (reverse (cons (car vertices) (reverse (cdr vertices))))))
Greets reltro
pedroantonio
« Reply #2 on: May 10, 2014, 10:13:25 AM »
Hi reltro
1. Select Polyline
2. Pick the Point
this is exactly what i am looking for , but this code after select the polyline stops ....
reltro
« Reply #3 on: May 10, 2014, 10:28:11 AM »
sure it stops, all has to have an end ;)
look at his name! its called: "From1to4"
its just a Part...
Try coding yourself!
pedroantonio
« Reply #4 on: May 10, 2014, 10:38:17 AM »
Thanks you for your time reltro
pedroantonio
« Reply #5 on: May 14, 2014, 05:12:40 AM »
Can anyone help
ChrisCarlson
« Reply #7 on: May 14, 2014, 08:05:58 AM »
Where have you left off? What part are you stuck on?
pedroantonio
« Reply #8 on: May 14, 2014, 12:17:26 PM »
The polyline have allready attribiute blocks on it .The only thing i want to do is to increase the value of attribute block along a polyline clockwise all the times like this
1,2,3,4,5,6,7,8,...............
Or
Giving a letter first like
K1,K2,K3,K4,..........................
T1,T2,T3,.............................
1) first select the polyline .(The polyline have allready attribiuts on it)
2) Give or not a letter
3)Pick the first point (the point that will have the number 1 or K1 etc...)
4) increase the value of attribute block along a polyline clockwise
ChrisCarlson
« Reply #9 on: May 14, 2014, 04:24:06 PM »
I'm not sure how to gather the coordinates in a clockwise fashion but if it's not many attributes you can just manually select them one at a time?
(setq num_seq
    (getint
      (strcat "\nStarting number <"
         (itoa num_seq)">: ")))
(car (nentsel "\n--- SELECT ATTRIBUTE ---- ")))
(if (and curText ;
                 (setq curData (entget curText))
                 (= (cdr (assoc 0 curData)) "ATTRIB")
            (vla-put-TextString
(vlax-ename->vla-object curText)curStr)
(setq num_seq(1+ num_seq))
        (princ "\n--- THIS IS NOT AN ATTRIBUTE ---- ")
pedroantonio
« Reply #10 on: May 14, 2014, 04:31:26 PM »
Thank you ChrisCarlson but i want to  increase the value of attribute block along a polyline clockwise  automaticaly all. Select only the first ,because i have a lot of points to rename...
pedroantonio
« Reply #11 on: May 16, 2014, 01:28:37 AM »
is it possible to  increase the value of attribute block along a polyline clockwise  automaticaly. and how?
« Reply #12 on: May 16, 2014, 08:56:53 AM »
Perhaps a bit of searching will lead you in the right direction
http://goo.gl/M9O64C
http://goo.gl/GhIaYY
pedroantonio
« Reply #13 on: May 16, 2014, 04:07:16 PM »
can anyone help with the code ?
« Reply #14 on: May 16, 2014, 04:09:27 PM »
