Author Topic: Fields in Dynamic Block  (Read 6350 times)
MaDcAdDeR
« on: May 08, 2014, 01:02:09 PM »
I havent really used Dynamic blocks alot and was wondering if this is possible to do this or
if there is something else I can use/do in AutoCad to achive the end result.
I want to make a rectangular dynamic block that will stretch incramentally both horizontally and vertically
and update the attributes in my example.
Im assuming fields would need to be use used instead of attributes.
I think the length, width, and area would be easy but, Im not quite sure how I would be able to have a
field for the cost and the weight. Maybe a table/excel file?
Thanks for the Help! :-)
« Last Edit: September 26, 2014, 11:47:22 AM by MaDcAdDeR »
Re: Fields in Dynamic Block
« Reply #1 on: May 08, 2014, 01:07:57 PM »
you can add a formula
in attached see the formula uses the AREA of an object to calculate something
« Last Edit: May 08, 2014, 01:11:01 PM by mjfarrell »
MaDcAdDeR
« Reply #2 on: May 08, 2014, 01:24:28 PM »
Thank you mjfarrell!
Thats awsome, you have no Idea how much time this will save me.  :-D
« Reply #3 on: May 08, 2014, 02:15:01 PM »
Yes, yes I do.
We even found a way to do 3D dynamic block functions quite by accident one day  in a class.
Even though technically they only support 2d functions.
And for a guy in the Industrial Rack and Shelving business it was a huge obstacle to be able to conquer that.
MaDcAdDeR
« Reply #4 on: May 12, 2014, 01:50:21 PM »
I am in need of some help again.
I've created my dynamic block and everything is working good except for 1 thing.
I want the block with attributes within the dynamic block to be centered horizontally and vertically within the dynamic block.
I have already tried the move action with the linear parameter at a .5 multiplier as well as the stretch action with the same multiplier.
As it was shown on www.cad-notes.com/how-to-keep-attributes-at-dynamic-block-center/
Please note the block was created in ADT07 educational version.
Thanks again!
« Last Edit: September 26, 2014, 11:46:53 AM by MaDcAdDeR »
MaDcAdDeR
« Reply #5 on: May 12, 2014, 03:19:15 PM »
And 1 more thing,...there will be multiple instances of this dynamic block in a drawing with varying sizes to cover different size areas of a floor plan.
How can I have the data update in those other instances instead of it looking at the first instance?
Thank you!
snownut2
  • Bricscad 22 Ultimate
« Reply #6 on: May 12, 2014, 06:07:56 PM »
Would you please do a search on this site "Educational Version"
MaDcAdDeR
« Reply #7 on: May 12, 2014, 07:01:41 PM »
Hi snownut2,
Is there a specific post or thread you are referring to?
I was just making it known so nobody copies something from the file and gets the watermark on their files.
Thanks.
snownut2
« Reply #8 on: May 12, 2014, 07:33:14 PM »
Nope, just trying to make you aware of the perils of the student versions.
Hope you don't plan on sending the plans to other users.
MaDcAdDeR
« Reply #9 on: May 12, 2014, 08:37:57 PM »
I am fully aware of the student version issue and would not send it to anyone without them knowing about it first. hence my "please note"
**Warning** to anyone who downloads the D-Mesh.dwg on this thread please be aware that it was created with an educational version and ANYTHING copied from this file will place a permanent watermark on anything printed from that file.
As long as you don't copy anything from the file you will be fine & I would REALLY appreciate any help on the issues I'm having with making this dynamic block so i can get an upgrade at work and get stuff done faster and keep the rest of my hair. :-)
I am trying to get this dynamic block working on my personal bought and paid for student version of ADT07 so I can show it to my manager (on my laptop only) as an example only of how much time/money/etc the latest version will save the company so he can justify us upgrading from AutoCAD 2002. To me (and probably everyone on here) it's a no-brainer but they want to see stuff so here I am.
Thanks.
johnratliff
« Reply #10 on: May 20, 2014, 02:03:21 PM »
Doing this from memory; To remove the educational version, insert the file through a reference using a licensed version and it should get filtered out.
