hi all, here i attempted dxf-modify method in order to justify code 71 .Then i applied a lambda to determine the best quadrant if the text reaches each end corner, so it can be seen (not exceed screen or hidden)
lastly, applied to suit current UCS. thank you
i remarked with double asterisk **
;"Grread with MTEXT by ymg"
; version: ymg -> reltro -> alanjt
; http://www.theswamp.org/index.php?action=post;msg=521731;topic=46966.30
; similar reference tread http://www.lee-mac.com/grtext.html
; ** --> partial commented with ** attempted by hanhphuc
(defun c:test (/ etxt p prvtext scl str txt txtp xog yof ini*error* catch
vec ); **
(defun ini*error* (name sysvars / *doc*)
(vla-startundomark (setq *doc* (vla-get-activedocument (vlax-get-acad-object))))
(eval
(list 'defun '*error* '(msg / )
(list
(lambda (name prevErrorHandler SysVars *doc* currentcmdecho / )
(mapcar
'setvar
(mapcar 'car SysVars)
(mapcar 'cdr SysVars)
(vla-endundomark *doc*)
(setq *error* prevErrorHandler)
(if msg
(setvar 'cmdecho 0)
(command-s "_.undo" 1 "")
(setvar 'cmdecho currentcmdecho)
(princ "\n*** error ***\n")
(princ (strcat "\t" name ": " (vl-princ-to-string msg) "\n"))
(*error* msg)
(vl-princ-to-string name)
*error*
(list 'quote
(mapcar
'(lambda (a / ) (cons a (getvar a)))
sysvars
*doc*
(getvar 'cmdecho)
(ini*error*
"Grread with MTEXT - ymg"
'("CLAYER" "OSMODE" "CMDECHO" "DIMZIN")
(setvar 'osmode 0)
(setq catch
(vl-catch-all-apply
'(lambda ( / )
(setq
xof 30
yof -30
scl (/ (getvar 'viewsize) (cadr (getvar 'screensize)))
(while
(= 5 (car (setq p (grread nil 13 0))))
(setq Vcp (trans (getvar "viewctr") 1 0) ; ** setq vcp
p (trans (cadr p) 1 0 t) ; ** trans
vec ; ** setq vec
(mapcar
'(lambda (x)
(equal (mapcar '>= p Vcp) x)
'((T T T) (nil T T) (nil nil T) (T nil T))
) ; ** mapcar
(cond ((nth 0 vec)
(setq xof -15
yof -15
((nth 1 vec)
(setq xof 15
yof -15
((nth 2 vec)
(setq xof 15
yof 15
((nth 3 vec)
(setq xof -15
yof 15
) ; ** cond
(setq
;;; p (cadr p) ; ** removed
str (mapcar 'rtos (trans p 0 1)) ; ** trans UCS
txtp (list (+ (car p) (* xof scl)) (+ (cadr p) (* yof scl)))
txt (strcat "X= " (car str) "\\PY= " (cadr str))
(setq etxt (list (cons 0 "MTEXT")
(cons 100 "AcDbEntity")
(cons 62 2)
(cons 100 "AcDbMText")
(cons 10 txtp)
(cons 40 (* 10 scl))
(cons 1 txt)
(if prvtext
(entdel prvtext)
prvtext
(mapcar '(lambda (x y) (dxfmod prvtext x y))
'(10 40 1 62) (list txtp (* 10 scl) txt 2))
(setq prvtext (entmakex etxt))
) ; ** dxfmod & entmakex
(cond ((nth 0 vec) (dxfmod prvtext 71 3))
((nth 1 vec) (dxfmod prvtext 71 1))
((nth 2 vec) (dxfmod prvtext 71 7))
((nth 3 vec) (dxfmod prvtext 71 9))
) ; ** cond
;;;(setq prvtext (entlast)) ; **
); while
(if prvtext (entdel prvtext))
(princ )
;;;(setq prvtext (entmakex etxt)); **
(if (vl-catch-all-error-p catch)
(*error* (vl-catch-all-error-message catch))
catch
(*error* nil)
; ** hp#007
(defun dxfmod (_e _i val / lst ) ; (dxfmod entity index new-value )
(setq lst (entget _e)) ; old dxf list
(if (assoc _i lst)
(entmod (subst (cons _i val)
(assoc _i lst)
lst
) ;subst old to new
(entmod (append lst (list (cons _i val)))) ; add new to dxf
) ; if
