Author Topic: Number conversions  (Read 2019 times)
Biscuits
Number conversions
« on: May 02, 2014, 02:02:41 PM »
Hi gang............long time no see.
Using Windows 7 and Autocad 2013
I have a huge project coming up where we need to change numbers in our bills of materials from fractions to 2 place decimal. This is all in regular text (not dimensions or attributes).
Examples:  1 1/2 to become 1.50, 2 to become 2.00, 3 11/16 to become 3.69, etc.
Two decimal places are required including trailing zeros.
I'm looking to create a routine that would allow a single or window selection.
I've searched the web with no success. How should I start something like this?
Thanks for any ideas.
Re: Number conversions
« Reply #1 on: May 02, 2014, 03:54:16 PM »
Start with Pseudo Code.
ymg
« Reply #2 on: May 02, 2014, 07:00:16 PM »
It very much  depends on your data.
Here is a small routine that I had in another program that
I have quickly adapted.
; Split the supplied string lstr on delimiters list                           ;
; Otherwise returns a list of string segments.                                ;
(defun parsestr (lstr delimit / bpos epos error segm rtnlst)
     (setq bpos 1)
     (while (and delimit (not error))
(if (setq epos (vl-string-search (car delimit) lstr))
    (setq   segm (substr lstr bpos (- (+ epos 1) bpos))
            segm (vl-string-trim " " segm)
          rtnlst (cons segm rtnlst)
            bpos (+ epos (strlen (car delimit)) 1)
         delimit (cdr delimit)
    (setq error t)
     (setq rtnlst (reverse (cons (substr lstr bpos (- (+ (strlen lstr) 1) bpos)) rtnlst))
           rtnlst (vl-remove "" rtnlst)
(defun c:test (/ data delimiters  l n)
  (setq data '("1 1/2" " 2" "3 11/16"))
  (setq delimiters '(" " "/"))
  (foreach num data
     (setq l (parsestr num delimiters))
     (setq n (+ (atof (car l)) (if (cadr l) (/ (atof (cadr l)) (atof (caddr l))) 0)))
     (princ (strcat "\n" num " -> " (rtos n 2 2)))
Result for supplied Data List:
1 1/2 -> 1.50
 2 -> 2.00
3 11/16 -> 3.69
ymg
irneb
« Reply #3 on: May 03, 2014, 01:08:23 AM »
Another thread concerning extracting the numbers out of text (including fractions) so you can convert them to other representations: http://www.theswamp.org/index.php?topic=38779.0
Stefan
  • The most I miss IRL is the Undo button
« Reply #4 on: May 03, 2014, 04:26:41 AM »
  1. _$ (setvar 'dimzin 1)
  2. 1
  3. _$ (rtos (distof "1 1/2") 2 2)
  4. "1.50"
  5. _$ (rtos (distof "2") 2 2)
  6. "2.00"
  7. _$ (rtos (distof "3 11/16") 2 2)
  8. "3.69"
  9. _$
ymg
« Reply #5 on: May 03, 2014, 10:35:33 AM »
distof is certainly simpler, though we needed the the double quotes at the end.
ymg
mailmaverick
« Reply #6 on: May 03, 2014, 02:22:41 PM »
Dear Stefan, when we supply fraction to distof, thhen why doesn't we need to give mode as 5 ?.
(distof string [mode])
Modes :
1 Scientific
2 Decimal
3 Engineering (feet and decimal inches)
4 Architectural (feet and fractional inches)
5 Fractional
Stefan
« Reply #7 on: May 03, 2014, 03:43:24 PM »
Modes :
1 Scientific
2 Decimal
5 Fractional
Modes 1, 2 and 5 are pretty much the same: the integer part and the fractional part. Autocad does recognize the fractional part either as floating point or as a fraction of two integers. For example, try "scale" command and specify 0.25 as scale factor. Now try again and enter 1/4 as scale factor. The results are the same (as a side note, I use this a lot instead of classical "reference" option in scale command  :-)).
The mode is optional in distof function, but it must be used when the first argument (string) is engineering or architectural type.
ymg
« Reply #8 on: May 03, 2014, 04:11:43 PM »
stefan,
I also find distof a little finicky as to the format.
Say I have as  a string "1  1/2" that is two spaces I will get nil as a result.
(distof "1  1/2")
nil
_$ (distof "  1 1/2  ")
nil
_$ (distof " 1 1/2")
nil
As a minimum we would need to vl-string-trim what we are passing to it.
ymg
ymg
« Reply #9 on: May 03, 2014, 05:26:09 PM »
Biscuits,
To help you any further we would need at least a sample drawing
ymg
Biscuits
« Reply #10 on: May 05, 2014, 11:58:54 AM »
Took a bit of stumbling but I got something here that does the job.
Thanks to everyone for your help.
Biscuits
;  This routine will convert ( text only ) inches w/fractions to 2 place decimal
;  EXAMPLE: "46 11/16" will convert to "46.69"
;  Caution: Existing decimals will convert to 2 places if included in the selection
(defun c:Frac-Dec (/ EntProps SS Imp Dist)
  (if (setq SS (ssget (list (cons 0 "TEXT"))))
    (foreach EntName (vl-remove-if 'listp (mapcar 'cadr (ssnamex SS)))
      (if (setq EntProps (entget EntName)
Imp (cdr (assoc 1 EntProps))
Dist (distof Imp 4)
(entmod
  (subst
    (cons 1
  (strcat (rtos (cvunit Dist "INCHES" "INCHES") 2 2))
    (cons 1 Imp)
    EntProps
