Author Topic: VBA to Open Drawing in Read Only  (Read 3345 times)
MSTG007
« on: April 29, 2014, 01:21:52 PM »
How can I modify the following code to have the file always open up in Read Only oppose to write mode. The file I have is a master template that will keep getting updated.
Public Graphics As AcadApplication
Public Sub Loadtemplate(control As IRibbonControl)
    Dim strDrawing As String
    On Error Resume Next
    Set Graphics = GetObject(, "AutoCAD.Application")
    If Err.Description > vbNullString Then
        Err.Clear
        Set Graphics = CreateObject("AutoCAD.Application")
    End If
    strDrawing = "c:\temp\master.dwg"
    Graphics.Documents.Open (strDrawing)
    On Error GoTo 0
End Sub
Thanks for the help!!!!
Civil3D 2020
ssaqibh
Re: VBA to Open Drawing in Read Only
« Reply #1 on: April 30, 2014, 01:01:41 AM »
Try
 Graphics.Documents.Open strDrawing, true
MSTG007
« Reply #2 on: April 30, 2014, 07:09:25 AM »
Works! Thank you.
Civil3D 2020
