I worry about the correctly working of AUDIT, or Previous selection in the AutoCAD 2015...
AutoCAD 2015:
- Run acad.exe
- Create a new document based on any DWT template.
- Run the _AUDIT command with "_N" option.
- Look the last string of AUDIT report.
- Repeat launching the _AUDIT with "_N" option
- Look the last string of AUDIT report (compare this with the previous result).
Note: This occurs if previous acad.exe session was AutoCAD 2015 too (instead of AutoCAD's older version).I see something like this, often:
Command: AUDIT
Fix any errors detected? [Yes/No] <N>:
Auditing Header
Auditing Tables
Auditing Entities Pass 1
Pass 1 100 objects audited
Auditing Entities Pass 2
Pass 2 100 objects audited
Auditing Blocks
1 Blocks audited
Auditing AcDsRecords
Total errors found 0 fixed 0
Erased 0 objects
Previous selection set contains 7536754 paper space 7274610 model space objects
Command: AUDIT
Auditing Header
Auditing Tables
Auditing Blocks
1 Blocks audited
Erased 0 objects
Previous selection set contains 2097260 paper space 6357108 model space objects
Anybody get the similar results?
P.S. I use a "clear" AutoCAD 2015, without my additional plugins (it is for testing, but is not for working).
