Author Topic: AutoCAD 2015 & (Audit | Previous selection)  (Read 2851 times)
Andrey Bushman
« on: April 28, 2014, 09:59:07 AM »
I worry about the correctly working of AUDIT, or Previous selection in the AutoCAD 2015...
AutoCAD 2015:
  • Run acad.exe
  • Create a new document based on any DWT template.
  • Run the _AUDIT command with "_N" option.
  • Look the last string of AUDIT report.
  • Repeat launching the _AUDIT with "_N" option
  • Look the last string of AUDIT report (compare this with the previous result).
Note: This occurs if previous acad.exe session was AutoCAD 2015 too (instead of AutoCAD's older version).
I see something like this, often:
Quote from: AutoCAD 2015
Command: AUDIT
Fix any errors detected? [Yes/No] <N>:
Auditing Header
Auditing Tables
Auditing Entities Pass 1
Pass 1 100     objects audited
Auditing Entities Pass 2
Pass 2 100     objects audited
Auditing Blocks
 1       Blocks audited
Auditing AcDsRecords
Total errors found 0 fixed 0
Erased 0 objects
Previous selection set contains 7536754 paper space 7274610 model space objects
Command: AUDIT
Auditing Header
Auditing Tables
Auditing Blocks
 1       Blocks audited
Erased 0 objects
Previous selection set contains 2097260 paper space 6357108 model space objects
Anybody get the similar results?
P.S. I use a "clear" AutoCAD 2015, without my additional plugins (it is for testing, but is not for working).
« Last Edit: April 28, 2014, 12:57:23 PM by Andrey Bushman »
Andrey Bushman
Re: AutoCAD 2015 & (Audit | Previous selection)
« Reply #1 on: April 28, 2014, 12:57:45 PM »
Bug was confirmed and sent to ADN.
« Last Edit: April 29, 2014, 12:04:26 AM by Andrey Bushman »
« Reply #2 on: April 28, 2014, 04:49:49 PM »
Thanks Andrey.
