Author Topic: Linetype scale  (Read 7281 times)
2e4lite
Linetype scale
« on: April 26, 2014, 02:21:31 AM »
   I has been trouble  in the  linetype scale all along .  Those of some lines such as CENTER and DASH  shown with continuous. The length of objects have a large range in a drawing .So I want  a lisp routine that can automatically adjust it using the proper  scales according  to the length of  every object for the whole drawing . It will go a long way in my work . How to acheive it?
« Last Edit: April 29, 2014, 03:20:48 AM by 2e4lite »
snownut2
  • Bricscad 22 Ultimate
Re: Linetype scale
« Reply #1 on: April 26, 2014, 07:24:54 AM »
Why not start by doing a little searching on here, Google and the other CAD sites....
2e4lite
Re: Linetype scale
« Reply #2 on: April 26, 2014, 09:27:18 PM »
I 've done it ,but some  lisp routines  are not to adjust the  scales  by  length,it is different from what I want.
Re: Linetype scale
« Reply #3 on: April 26, 2014, 10:07:19 PM »
Computer programs need rules.
To achieve what you want : What are the rules, exactly ?
2e4lite
Re: Linetype scale
« Reply #4 on: April 26, 2014, 10:36:07 PM »
 Thanks to Kerry, Perhaps the words have a distance . I just want to achive the result like the following attachment.(ps: It also effect to block)
« Last Edit: April 28, 2014, 09:39:00 PM by 2e4lite »
Re: Linetype scale
« Reply #5 on: April 26, 2014, 10:47:41 PM »
Great pictures, but what are the rules ?
What LineTypeScale do you want to use for different length lines ?
Does your setup change the global LTSCALE variable depending on DIMSCALE for the document ?
Can we assume you want to select the lines to modify ?
2e4lite
Re: Linetype scale
« Reply #6 on: April 26, 2014, 11:40:18 PM »
   Under the result premise ,You can have a think to the rules.Whatever LineType scales will to be set , I think , It is good as long as it can be easily distinguish between non-continuous and continuous shown on computer and in drawing sheet .It seems not change the global LTSCALE variable depending on DIMSCALE for the document .We usually draw the plant using the scale of 1:1 . the DIMSCALE and ltscale are set 1 in general . It is required to have two chooses to modify the non-continuous for users: to modify the whole drawing automatically (default) and to give ranges in the drawing to modify automatically.
« Last Edit: April 30, 2014, 01:47:23 AM by 2e4lite »
Re: Linetype scale
« Reply #7 on: April 26, 2014, 11:56:49 PM »
OK, so you want to set the individual LinetypeScale property for specific objects.
2e4lite
Re: Linetype scale
« Reply #8 on: April 27, 2014, 12:22:38 AM »
Yeah...
Re: Linetype scale
« Reply #9 on: April 27, 2014, 07:46:07 PM »
The path to quality software begins with excellent requirements. Slighting the processes of requirements development and management is a common cause of software project frustration and failure.
dgorsman
Re: Linetype scale
« Reply #10 on: April 28, 2014, 10:19:02 AM »
My version: code is the end result, not the starting point.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
irneb
Re: Linetype scale
« Reply #11 on: April 29, 2014, 04:13:37 AM »
You could try this I suppose
  1. (defun Get-Entity-Linetype  (eObj / lt)
  2.   (if (wcmatch (strcase (setq lt (vla-get-LineType eObj))) "BYLAYER")
  3.     (cdr (assoc 6 (tblsearch "LAYER" (vla-get-Layer eObj))))
  4.     lt))
  5.
  6. (defun Get-LineType-Pattern-Length  (ltName)
  7.   (apply '+
  8.          (mapcar '(lambda (c)
  9.                     (cond ((= (car c) 49) (abs (cdr c)))
  10.                           (t 0)))
  11.                  (tblsearch "LTYPE" ltName))))
  12.
  13. (defun Set-Entity-Min-LtScale  (eName / eObj len ltlen)
  14.     (setq eObj (vlax-ename->vla-object eName))
  15.     (if (< (setq len (vla-get-Length eObj))
  16.            (setq ltlen (Get-LineType-Pattern-Length (Get-Entity-Linetype eObj))))
  17.       (/ len ltlen)
  18.       1.0)))
  19.
  20. (defun c:SetMinLtScales  (/ ss n)
  21.   (if (setq ss (ssget '((0 . "LINE"))))
  22.     (repeat (setq n (sslength ss)) (Set-Entity-Min-LtScale (ssname ss (setq n (1- n))))))
  23.   (princ))
Should work for Lines. Might need a bit more for other types of objects (e.g. circles / arcs / polylines / etc.)
irneb
Re: Linetype scale
« Reply #12 on: April 29, 2014, 04:15:25 AM »
  4.     lt))
  5.
  7.   (apply '+
  10.                           (t 0)))
  12.
  17.       (/ len ltlen)
  18.       1.0)))
  19.
  23.   (princ))
And you'd need to accommodate for the global LTScale factor, or even the paper-space factor (if PSLTSCale=1) or even worse - what about AnnoScales?
Re: Linetype scale
« Reply #13 on: April 29, 2014, 05:40:14 AM »
Yes.
And there is still my original question .. What individual LTScale will be used for differing line lengths.
And he'd need to consider several different line types and variation in stroke length within each basic type.
The actual code is pretty basic ... setting the rules is where the work needs to be done.
It astounds me that anyone can ask [us] to code a routine like this and is not prepared to do the work involved in actually explain what is required.
Some problems are interesting in themselves technically and are worth spending the time on, but I really hate wasting time trying to extract basic design data related to the problem.
I see it all too often and it continues to piss me off.
« Last Edit: April 29, 2014, 05:46:16 AM by Kerry »
tedg
Re: Linetype scale
« Reply #14 on: April 29, 2014, 11:06:05 AM »
I'm not sure the op got the hint ....
"Hey 2e4lite, can you respond with a clear explaination of what you would like for the rules for this program to run under, and maybe you could get some help here?"
Windows 10 Pro 64bit, AutoCAD 2023, REVIT 2023
