Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
CAD Forums
CAD General
Topic:
How to delete the specified section?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: How to delete the specified section? (Read 2333 times)
2e4lite
Guest
on:
April 24, 2014, 09:43:15 PM »
How to delete the specified section as fig.2 by using the command of break?
Logged
Seagull
Every Student their own Lesson
WWW
Re: How to delete the specified section?
Reply #1 on:
April 24, 2014, 09:48:58 PM »
best to use the TRIM command instead
because you can not know which direction the rectangle was drawn from looking at it
Logged
Mesozoic relic
Seagull
class keyThumper<T>:ILazy<T>
Reply #2 on:
April 24, 2014, 09:50:04 PM »
TRIM
=> select the Pline
When prompted for the object to trim :
=> Select a crossing of the corner with the 2 sides to be removed.
PS I have assumed the original is a PLine.
Otherwise just delete what you don't want.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
CAD Forums
CAD General
Topic:
