Author Topic: Translate from model space to paper space without using COM code  (Read 2644 times)
cannorth
Hello,
  I'd like to know if there's code for this:
                vPtMs = CType(ThisDrawing.ActiveDocument.Utility.TranslateCoordinates(CType(vPt, Object), AutoCAD.Interop.Common.AcCoordinateSystem.acDisplayDCS, Autodesk.AutoCAD.Interop.Common.AcCoordinateSystem.acPaperSpaceDCS, 0), Object)
In VB.Net ObjectARX.
Thanks,
cannorth
cannorth
Re: Translate from model space to paper space without using COM code
« Reply #3 on: April 25, 2014, 11:48:44 AM »
What's the DLLImport statement and parameters for acedTrans?
cannorth
« Reply #4 on: April 26, 2014, 08:51:55 AM »
cannorth
I assume you didn't read the thread I listed ??
