Author Topic: BlackBox!!  (Read 11308 times)
ROBBO
Re: BlackBox!!
« Reply #15 on: May 09, 2014, 09:29:13 AM »
Thank you very much. I left out the last pause - that's why it didn't work!
The only thing to do with good advice is to pass it on.
It is never of any use to oneself.
Oscar Wilde
(1854-1900, Irish playwright, poet and writer)
BlackBox
Re: BlackBox!!
« Reply #16 on: May 09, 2014, 09:47:59 AM »
Hello BlackBox,
The double snap cursor menu is a great idea. Is it possible to show me how to create this in the cui?
Many thanks in advance, Robbo.
Yeah, BBox...finally have some time to spend with this and I'm in the CUI but having time locating where I'd add these double-snaps....can you explain the procedure to create such a menu for us? Please and thanks
Hi guys,
Sorry to keep you waiting; I'm having a pretty crazy week, but will get back to you on this.
Thanks for your patience. :-)
For the purposes of this example, we're going to assume that these CUI changes are being made to Main CUI.
The first thing I would do, is to decide what double snaps you want, and how you'd like them to be grouped.
With that outlined, in CUI Editor, you're going to be adding a new CUI Command (macro) for each-and-every-single double snap you desire, which is a good place to have some standardized naming convention, in order to make additions, and modifications especially, easy to find after the fact.
When creating these double snap CUI Commands, be sure to exclude the typical ^C^C prefix, as the intent here is to call these macros while in an active command, and you do not want to 'cancel' same.
Once you've created your individual double snap CUI Commands, you create a new Shortcut Menu, and give it an appropriate name. Make note of the Alias assigned to this new Shortcut Menu, you'll need that later. For this example, the Alias value is POP123.
To add CUI Commands to your new Shortcut Menu, in the lower left pane of the CUI Editor, select each of your newly added double snap CUI Commands, and drag them to your new Shortcut Menu. If you've named them so they're grouped together, multiple selection is easy. If not, well, perhaps you should reconsider that decision. LoL
With your double snap CUI Commands added to the Shortcut Menu, create another CUI Command which calls your Shortcut Menu's $P0=POP123 $p0=* macro.
Now, expand the Mouse Buttons node of the upper left pane.
For this example, we'll leave the Shift+Click as default Snap Menu. Now expand the Ctrl+Click node, remove the button assignments as desired, and ensure that either the top button assignment (button 2) is clear, or that you're comfortable with overwriting it.
Select your new Shortcut Menu's CUI Command, and drag & drop it on the Button2 Mouse Button.
This is merely a quick and dirty tutorial; I'll come back when I have time and dress it up with screen shots, etc.
Cheers
« Last Edit: May 12, 2014, 11:31:31 AM by BlackBox »
ROBBO
Re: BlackBox!!
« Reply #17 on: May 11, 2014, 04:46:06 AM »
Thank you BB. Very clear instructions to follow. My new shortcut menu is well on its way. Be interesting to see if I can get it to work with my Enterprise CUIx once complete.
Oscar Wilde
BlackBox
Re: BlackBox!!
« Reply #18 on: May 11, 2014, 10:43:50 AM »
You're welcome, ROBBO; I really should gather up the few good tutorials I've posted, and add them to my website. LoL
In any event, as to Enterprise CUI, what happened with this???
http://www.theswamp.org/index.php?topic=47009.msg520472#msg520472
ROBBO
Re: BlackBox!!
« Reply #19 on: May 11, 2014, 12:12:33 PM »
I created a custom default right click menu in our custom Enterprise CUIx - P501, CMDEFAULT. Added a lisp in the Enterprise to run (menucmd "P501=MyEnterprise .CMDEFAULT") to replcace ACAD default. Also added a command to run (menucmd "P501=ACAD.CMDEFAULT")  to revert back to default in users ACAD.CUIx (and CIVIL.CUIx) if required.
I wouldn't want to discouraged users from customising their menus, etc. Therefore think the Enterprise CUIx approach is helpful and controlled centrally to help with our company standards and is easily setup and has the bonus of generally having precedence of any other cui loaded.
Cheers,  Robbo.
UPDATE: Added menu to Enterprise CUIx including Mouse Button assignments and unlike the default right menu, the ctrl+click in the Enterprise cui overrides the Main cuix  :-D.
« Last Edit: May 12, 2014, 03:41:18 PM by ROBBO »
Oscar Wilde
Bhull1985
Re: BlackBox!!
« Reply #20 on: May 12, 2014, 10:58:09 AM »
You're the man!
Now, time to read.
Alright was following steps pretty fluidly , not running into any issues until this happened, when trying to assign the newly created pop menu to a mouse button.
I tried re-sizing the panes and no luck, why don't I have the fields to assign pop to macro, as shown below?
(this is with Button2 selected, which has <none> next to it....what tha?!
« Last Edit: May 12, 2014, 11:10:30 AM by Bhull1985 »
BlackBox
Re: BlackBox!!
« Reply #21 on: May 12, 2014, 11:16:13 AM »
Perhaps I left out a step by mistake :|....
Once you've created all of your custom snap CUI Commands, and properly linked them to your custom Shortcut Menu, then create another CUI Command which calls your $P0=POP### $p0=* macro... With that, you simply drag & drop this last Shortcut Menu CUI Command to Button2.
Bhull1985
Re: BlackBox!!
« Reply #22 on: May 12, 2014, 11:19:28 AM »
Aha!
Thanks!
BlackBox
Re: BlackBox!!
« Reply #23 on: May 12, 2014, 11:32:14 AM »
Bhull1985
Re: BlackBox!!
« Reply #24 on: May 12, 2014, 11:40:29 AM »
Yep, got them working quite well, you're the man BB!
Thanks for this nice tip.
Apologies for the redundancy but I wanted you to know I had this working as intended.
BlackBox
Re: BlackBox!!
« Reply #25 on: May 12, 2014, 12:41:50 PM »
No worries; I appreciate the kind feedback, and am glad to help bring your seemingly out of reach request to fruition with just a few short posts. :beer:
Cheers
ROBBO
Re: BlackBox!!
« Reply #26 on: May 14, 2014, 10:59:31 AM »
If the shortcut menu and double snaps are added to a Partial Cuix, how can the ctrl+click in the partial cuix  take precedence over the default in the main cuix without editing the main menu group?
I tried (menucmd "A3=MyPartial.AUX3"), but menu was not reset.
Many thnaks in advance, Robbo.
Oscar Wilde
BlackBox
Re: BlackBox!!
« Reply #27 on: May 14, 2014, 11:01:18 AM »
Not sure that it can; I've only ever added these to a copy of the OOTB Main CUIx file used as our Profile's Main... Perhaps someone smarter than I will be along to educate us both.
Cheers
Bhull1985
Re: BlackBox!!
« Reply #28 on: May 15, 2014, 08:49:25 AM »
Well it may be possible but logically the keyboard/mouse shortcut menus SHOULD belong with the main CUIX in use.
If you've got 3 enterprise CUIX's all with different keyboard/mouse shortcuts and assignments, that would be one very messy setup. Not even sure if it'd work.
However, by restricting this sort of enhancement to the main CUIX, it ensures that it will be available while you are in any session with that software/CAD.
If you need to transfer this onto multiple machines then what I would do is "transfer" (via the CUIX) the keyboard shortcut menu (double osnap) to your ENTERPRISE cuix. Then save the enterprise. Do not remove from your main ACAD CUIX. Just get a COPY of it onto the enterprise, and then reload the enterprise on other machines, and then transfer the menu back from the ENTERPRISE to their now main ACAD cuix (per each machine you'd add them to).
BlackBox
Re: BlackBox!!
« Reply #29 on: May 15, 2014, 08:55:30 AM »
FWIW - Main CUIx is a Profile-dependent component.
It is for this reason, that I've historically worked in a production environment where both Main CUIx, and Enterprise CUIx (if included) are provided as part of our deployment, and in the case of Main, not mapped to the OOTB Main.
While the user does need to maintain write access to Main, we've always included a Custom CUIx as partial as part of our deployments. We can overwrite Main CUIx on user's accessible folders, and their Custom CUIx will still be loaded.
