Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
Code Red
.NET
Topic:
How can I assign all Cogo Points to an array?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: How can I assign all Cogo Points to an array? (Read 1266 times)
ekoneo
Newt
on:
April 24, 2014, 03:13:32 AM »
Anybody know that assigning all cogo points to an array?
Such as MyCogoARRAY.
Then I want to use that array MyCogoARRAY[5] that returning 5th cogo point's number or other properties.
Are there any way to do that?
Logged
Jeff_M
King Gator
C3D user & customizer
Re: How can I assign all Cogo Points to an array?
Reply #1 on:
April 24, 2014, 08:59:49 AM »
Code - C#:
[Select]
CivilDocument civdoc
CivilApplication
ActiveDocument
Document doc
acadApp
DocumentManager
MdiActiveDocument
Editor ed
doc
Editor
Database db
doc
Database
using
Transaction tr
db
TransactionManager
StartTransaction
PointGroup pg
PointGroup
civdoc
PointGroups
"_All Points"
GetObject
OpenMode
ForRead
uint
pointnums
pg
GetPointNumbers
//the array of Point #'s is not in any particular order, so convert to List & Sort...requires a using for Linq
List
uint
ptlist
pointnums
ToList
uint
ptlist
Sort
//if an array is really needed instead of the now sorted List, convert back to an array
pointnums
ptlist
ToArray
tr
Commit
Logged
ekoneo
Newt
Reply #2 on:
April 24, 2014, 10:05:13 AM »
Thanks again thanks thousands of thanks Jeff_M;
It works..
Thank you..
Logged
Print
Pages: [
1
Go Up
« previous
next »
Code Red
.NET
Topic:
