Author Topic: Drawing cylindrical break line ?  (Read 9812 times)
Tharwat
  • Hypersensitive
Re: Drawing cylindrical break line ?
« Reply #15 on: April 24, 2014, 11:25:13 AM »
ChrisCarlson
What do you mean by your reply with that image ?
ChrisCarlson
« Reply #16 on: April 24, 2014, 11:56:56 AM »
This forum has a plethora of information available and people still demand to be spoon fed  :ugly:
liuhaixin88
« Reply #17 on: April 24, 2014, 12:43:34 PM »
But as life gets busy and we forget about the smaller things, the kindness can be the first to go.
liuhaixin88
« Reply #18 on: April 24, 2014, 12:52:14 PM »
The routine is good! but have a little defects,
Here is similar one from my oldies, not tested in A2014,
temporarilly out of work...
Thank you , I test your code ,Results are as follows.
« Reply #19 on: April 24, 2014, 12:57:17 PM »
<sarcasm> You should have posted a larger image....<\sarcasm>  ::)
« Last Edit: April 24, 2014, 01:05:05 PM by ronjonp »
ChrisCarlson
« Reply #20 on: April 24, 2014, 01:01:44 PM »
I tried, the forum window'ed the image
roy_043
  • BricsCAD 18
« Reply #21 on: April 24, 2014, 03:42:16 PM »
:-D I thought you meant this:
RC
« Reply #22 on: April 24, 2014, 03:55:13 PM »
See "Autolisp - about this forum
Just a note to the new-comers about this forum that is vastly different from most. This place, TheSwamp, is a fishing school, generally, it will teach you how to fish. Often, they will help you land a fish you've already hooked and occasionally they will even offer a piece of fish to get you over a rough spot. Then every now and again, someone will give you a fish.
snownut2
  • Bricscad 22 Ultimate
« Reply #23 on: April 24, 2014, 04:34:08 PM »
However if you attempt to demand a fish with each post, you will quickly be back to chumming....
liuhaixin88
« Reply #24 on: April 24, 2014, 08:28:53 PM »
Ladies and gentlemen,
Thank you for your attention,
Theswamp.org is  a good forum, Thanks to everyone here.
fixo
« Reply #25 on: April 26, 2014, 03:25:15 AM »
Just change this line of code, if this will help
tested from A2007 through A2015:
(getpoint p1 "\nNew Location (starting fom first point): ")
liuhaixin88
« Reply #26 on: April 26, 2014, 03:35:50 AM »
Thanks fixo ,here have more wonderful answer :http://www.cadtutor.net/forum/showthread.php?85951-Drawing-cylindrical-break-line
snownut2
« Reply #27 on: April 26, 2014, 07:22:52 AM »
Someone needs to create a new BB site "Custom LISP FREE" special orders preferred, manners not required.
« Reply #28 on: April 26, 2014, 07:27:07 AM »
 :-D
Tharwat
  • Hypersensitive
« Reply #29 on: April 26, 2014, 07:29:39 AM »
+1 :lmao:
