Author Topic: Modal form in autocad  (Read 3263 times)
harksin
« on: April 21, 2014, 03:39:02 PM »
hello,
I try to build a modal form for user intercation, in autocad. I use c++ and objectARX 2013
can you help me a little bit?
at this time i have succes to display a Qt application in autocad, but this need +-30s and it can't be use in production...
i look for the the most simply methode to display modal form in autocad.
in fact i just need to make object selection, with an modal form because my programme core work on a external cluster to process faster.
thanks for your help
harksin
