Thanks Jeff_M and huiz.
Jeff_M you helped me in last week by this code about renumbering cogo points.
public void renumpnts()
CivilDocument civdoc = CivilApplication.ActiveDocument;
using (AcDb.Transaction tr = AcDb.HostApplicationServices.WorkingDatabase.TransactionManager.StartTransaction())
for (uint i = 1; i < 11; i++)
if (!civdoc.CogoPoints.Contains(i))
continue;
CogoPoint pt = (CogoPoint)civdoc.CogoPoints.GetPointByPointNumber(i).GetObject(AcDb.OpenMode.ForWrite);
pt.Renumber(i + 100, PointNumberResolveType.Overwrite);
tr.Commit();
And I add a for cycle in your code. Becouse I want to renumber all points starting from first available point to end one.
I can use it only once.. when I try to run it second time I get "Retrive attribute failed" error message.
Interestingly when I try to run second time, if I delette first point manually, it works..
my last work is:
using System;
using AcDb = Autodesk.AutoCAD.DatabaseServices;
using acadApp = Autodesk.AutoCAD.ApplicationServices.Application;
using Autodesk.Civil.ApplicationServices;
using Autodesk.Civil.DatabaseServices;
using Autodesk.Civil.Settings;
using Autodesk.Civil.DatabaseServices.Styles;
using Autodesk.Civil.Runtime;
namespace SelectionCommands
public class FilterSelect
[CommandMethod("FM")]
public static void AddParenthesis()
Document doc = acadApp.DocumentManager.MdiActiveDocument;
Editor ed = doc.Editor;
Database db = doc.Database;
Autodesk.Civil.ApplicationServices.CivilDocument CivilDoc = Autodesk.Civil.ApplicationServices.CivilApplication.ActiveDocument;
Autodesk.Civil.Settings.SettingsCmdCreatePoints CmdPointSettings = CivilDoc.Settings.GetSettings<Autodesk.Civil.Settings.SettingsCmdCreatePoints>();
int NextNumber = (int)CmdPointSettings.PointIdentity.NextPointNumber.Value;
uint pek = UInt32.Parse(NextNumber.ToString());
for (uint i = 1, j = 1; i <pek; i++) // pek is the last point number
continue;
pt.Renumber(j, PointNumberResolveType.Overwrite);
j++;
tr.Commit();
doc.SendStringToExecute("._RE ", true, false, false);
ed.WriteMessage("Renumbered All Points.. !!" + "\n");
