Author Topic: error: ActiveX Server returned the error: unknown name: Centroid (SOLVED)  (Read 4429 times)
HasanCAD
This part of code
  (while T
    (setq p1 (getpoint "\nPick Point inside shape"))
    (vl-cmdf "_.-boundary" "_A" "_I" "_N" "" "_O" "_R" "" "_non" p1 "")
    (setq obj (vlax-ename->vla-object (entlast)))
    (setq cent (vlax-safearray->list (vlax-variant-value (vla-get-centroid obj))))
    (vl-cmdf "POINT" (trans cent 1 0))
    (vla-delete obj)
Working perfect but Gives Error
« Last Edit: April 16, 2014, 08:44:58 AM by HasanCAD »
Tharwat
  • Hypersensitive
Re: error: ActiveX Server returned the error: unknown name: Centroid
« Reply #1 on: April 16, 2014, 08:23:10 AM »
Remove the Symbol T that is in front of the while function .
HasanCAD
« Reply #2 on: April 16, 2014, 08:44:17 AM »
Perfect,
Thanks Tharwat
Tharwat
  • Hypersensitive
You're welcome anytime .
ymg
HasanCad,
In addition to Tharwat's suggestion, you will get this error when
the boundary command cannot find a closed boundaries.
So the error message you are seeing is telling you that
there is no closed boundaries around the point you have chosen,
therefore no centroid.
In other word obj does not exist.
ymg
alanjt
  • Standby for witty remark...
Consider this...
(while (setq p1 (getpoint "\nPick Point inside shape"))
  (setq obj (entlast))
  (if (not (equal obj (setq obj (entlast))))
    (progn (vl-cmdf "_.point" "_non" (trans (vlax-get (setq obj (vlax-ename->vla-object obj)) 'Centroid) 1 0))
           (vla-delete obj)
    (princ "\nCentroid could not be determined.")
Dropbox
HasanCAD
Thnaks ymg
good trick alanjt
alanjt
Dropbox
